Change spark plugs for a turbo setup?
I'm in the process of putting my kit on and i was wondering, is it crucial to change your plugs for a turbo setup...i have ngk iridium ix's and i was going to go w/ ngk r's...good?
yea go w/ngk coppers. i beleve the 3330's are one heat range colder as per gude.
Modified by fastludeh22 at 12:18 PM 10/18/2003
Yes, you have to change them to a colder plug. The iridium's are a waste of money. Get these from your local auto zone/ advanced auto:
NGK BCPR7ES, part number 3330
Then gap them to .030
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">Yes, you have to change them to a colder plug. The iridium's are a waste of money. Get these from your local auto zone/ advanced auto:
Then gap them to .030</TD></TR></TABLE>
i thought it was .028
It depends on how much power you are planning on putting out and what type of ignition system you are using.
.028-.030 is fine
I run a .025 on my setup for 20psi.
.028-.030 is fine
i'm running bkr6e-11. i have to look for the box to get the stock #.
got mine gapped to .035. running msd digi 6/hvc coil, ngk wires. 8 psi(if i can get it to stop creeping.)
edit: just read some ggod stuff, going to try a 7 or even 8.
https://honda-tech.com/zerothread?id=510127
Modified by fastludeh22 at 12:19 PM 10/18/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">It depends on how much power you are planning on putting out and what type of ignition system you are using.
.028-.030 is fine
I run a .025 on my setup for 20psi.</TD></TR></TABLE>
Is your lude a daily driver? (street legal
.028-.030 is fine
Yes it is a street legal daily driver
I do have an extra car now so I will be using my JDM's out camry for my commutes to school, the bars downtown, and whenever the weather sucks.
