Headlight switch and a "hot" smell.
Old Oct 13, 2003 | 05:42 AM
AMChev's Avatar
Default Headlight switch and a "hot" smell.
A couple of days ago my headlight switch started acting up. I'd turn on the lights but the dash lights wouldn't come on. I can wiggle the switch and the dash lights will come on.
The next day I started noticing a "hot" smell, you know the smell that a wires insulation gives when it's hot. After some troubleshooting, I figured out that it's only when the lights are on. I can hear my alternator load up when I turn on the lights! The fuses aren't blown, the 10A fuse that controls the dash lights is kinda melted but not blown! I noticed one small wisp of smoke come from somewhere around the steering column but I can't find the hot wire.
Would a bad switch cause this or have I got bigger problems?
Old Oct 13, 2003 | 10:12 AM
crxforum's Avatar
Default Re: Headlight switch and a "hot" smell. (AMChev)
Take a wire checker and make sure that all the wires to the lights are not broken or cracken inside of the houising. The replace the fuses to double check. Also could the dash lights not be coming on becasue you bumped that little dimmer switch to off. That happened to me and it took me 5 min to figure it out.
CRX Forum
Old Oct 13, 2003 | 12:57 PM
AMChev's Avatar
Default Re: Headlight switch and a "hot" smell. (crxforum)
It isn't the dimmer... they'll come on if I wiggle the switch. I just think it's too much of a coincidence. I just don't understand why the fuse isn't blowing... maybe I got a defective fuse!
Old Oct 13, 2003 | 01:29 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
If the switch is not making good contact,
The resistance is increased which increases the amount of current needed to feed the circuit..
and That is why it is getting hot...Clean the contacts inside or replace the switch..
Old Oct 14, 2003 | 05:16 AM
AMChev's Avatar
Default Re: Headlight switch and a "hot" smell. (88DXCRX)
That's what I'll do, I'll try cleaning it first.
What is puzzling is that the fuse is all melted but not blown!
cgjarvis
10
Aug 7, 2016 12:22 PM
Johnoolo
Jan 17, 2014 08:13 AM
italianchooch88
Feb 13, 2008 01:45 PM
Timmay
38
Mar 17, 2006 01:26 AM
mustninty
Aug 17, 2004 03:26 AM
