Ring gap location? HELP
Me and a friend were assembling a motor and when he put the pistons in and had the top 2 ring gaps 180 degrees apart and in line with the piston pin and the lower 2 ring gaps 180 degrees apart and perpendicular to the piston pin. After installing the head, he realized the error. The crank is not in yet, we can move the pistons up and down, but the head is bolted on and all valvetrain installed. Is this a huge problem? Can we spin the pistons around and get the gaps to move around a little? Any ideas?
don't worry about the rings moving, they'll rotate anyway (I usually don't even worry about the gap, I just sorta don't put them over top each other), however, the head defintely needs to go on after the crank and recopricating assembly is in.
wreckedagain
21
Dec 15, 2005 12:19 PM
civic-si-2000
Oct 12, 2004 05:48 PM
