H22A Injectors in all motor B-Series....
Does anyone have H22A injectors in there all motor B-Series? What PSI are you guys running at and with what setting? I sold my header today and I replaced it with a stock B-series header. It ran kinda rich so I lowered my fuel pressure to about 30PSI. Its still running rich and its throwing a code 43 which is fuel system malfunction. I figure maybe cause its running too rich. Im running an lsvtec with CTR pistons and GSR cams... FPR, no cat, 2.5 exhaust... don't you think 30PSI is kinda low? I know prelude injectors are 345cc's, but im not sure PSI it takes for it to be 345cc. I was just wondering what you guys think...
i'm running the same setup and my fuel pressure is about 30psi on stock injectors, and it runs rich as hell! I REALLY DONT GET MUCH INFO ON LS/VTEC ON THIS FORUM, BUT MAYBE YOUR HAVIN BETTER LUCK!!! I'LL TRY IN KEEP UP WITH THIS FORUM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">B=240CC
H=???CC
any one know</TD></TR></TABLE>
92-96 Prelude "peak & hold" injectors (required fuel injector resistor box) are 330cc. The 97+ Prelude "saturated" injectors do not require a FI resistor box, and are 290cc. Both require different plugs on the harness.
H=???CC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-vtec1kid »</TD></TR><TR><TD CLASS="quote">i'm running the same setup and my fuel pressure is about 30psi on stock injectors, and it runs rich as hell! I REALLY DONT GET MUCH INFO ON LS/VTEC ON THIS FORUM, BUT MAYBE YOUR HAVIN BETTER LUCK!!! I'LL TRY IN KEEP UP WITH THIS FORUM
you're running 30psi with stock b-series injectors? what fuel pump are you running? you're using the stock ls headgasket with ctr pistons? when i had b-series injectors i had to run over 50PSI or i'd detonate.
</TD></TR></TABLE>you're running 30psi with stock b-series injectors? what fuel pump are you running? you're using the stock ls headgasket with ctr pistons? when i had b-series injectors i had to run over 50PSI or i'd detonate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil »</TD></TR><TR><TD CLASS="quote">So are you using the OBD 1 peak and hold injectors? Just curious.</TD></TR></TABLE>
i'm using the obd1 with the resistor box.
axtran
30
May 11, 2006 09:48 PM
