Need help with stock gsr manifold install!
Old Oct 12, 2003 | 09:44 PM
gorilla nasty's Avatar
Default Need help with stock gsr manifold install!
I just installed my stock gsr manifold after having the Skunk2 in for a few months. After putting everything back together like I thought was right I started up the car and the idle was all over the place. It stay at a steady 3grand for a minute then begins to bounce between about 1.5-3 grand. Also my ecu is throwing up a code 23(knock sensor). My question is, what can I do about the crazy idle and how would I go about fixing the CEL code? I need to sell the car as soon as possible. Any advice would be appreciated. thanks guys
Old Oct 12, 2003 | 09:54 PM
Brad's Avatar
I would double check the vacuum lines and make sure the knock sensor is pluged in all the way and not damaged from the installation.
Old Oct 12, 2003 | 09:57 PM
Roger's Avatar
Default Re: (Brad)
also make sure you got the vacuum lines going into the right areas.
Old Oct 12, 2003 | 10:18 PM
Default Re: (Roger)
yea that makes sense. but if the knock sensor was damaged how would i go about fixing it?
Old Oct 13, 2003 | 12:07 AM
Roger's Avatar
Default Re: (blackbeast)
if the knock is damaged, there isn't really not much you can do but to order another unfortunatley. try this place: http://www.acuraautomotiveparts.com. I got my knock sensor there and the durn around time is like 2-3 days. goodluck.
Kayronn Grier
Dec 3, 2015 06:24 AM
gapfast
Aug 1, 2008 10:46 AM
lshatch92
Feb 19, 2006 10:51 PM
xXx Justin xXx
Jun 11, 2004 02:01 AM
stephenB!
Mar 12, 2004 06:33 AM
