Pulleys?
Old Aug 30, 2001 | 06:35 PM
DaNish's Avatar
Default Pulleys?
Should I get the AEM Pulley's with the Altenator and Power Steering or the Unorthodox Pulley's which include Power Steering, Altenator and Crankshaft?
AEM Pulley's - $125
Unorthodox - $310
Is it that much of a difference?
Old Aug 30, 2001 | 06:40 PM
fixhondas's Avatar
Default Re: Pulleys? (X DaNish X)
The aem setup will be nicer on your motor- if you use unorthodox you will be removing the damper from the front of the crank (stock pulley) and this can be harsh on main bearings. The unorthodox would be quicker from the reduced mass.
Old Aug 30, 2001 | 06:41 PM
DragII's Avatar
25 Year Member
Default Re: Pulleys? (fixhondas)
Don't bother...they don't do much of anything, and cause more problems than they solve
Old Aug 30, 2001 | 06:44 PM
DaNish's Avatar
Default Re: Pulleys? (DragIIcivic)
Why do they cause more problems than they solve?
Old Aug 30, 2001 | 06:54 PM
DragII's Avatar
25 Year Member
alot of people have problems with not generating enough power for the alternater, and If the crankshaft pulley isn't balanced, it will deteriorate your engine little by little.
Even if they work fine for you, ie...no probs with them...you won't gain any power...the engine may rev a lil more freely, but you won't be that impressed.
Old Aug 31, 2001 | 06:03 AM
bigTom's Avatar
unless ur building a motor thats going to produce stupid amounts of hp... dont get them... they're just not worth the money
Old Aug 31, 2001 | 09:05 AM
maxim's Avatar
I totally agree...I have had my AEM pulleys(alt. and ps) for about 4 months and I have not really noticed any positive difference. The only difference is that my car's idle revs are pretty low(dead stall-500rpm) without the a/c on, though I don't know if that is it or not.
reymond_wit_a_01lude
Feb 1, 2007 04:39 AM
dc4teg95
Dec 11, 2006 12:37 AM
Integra21
Mar 22, 2006 05:09 AM
JdmFront619
Dec 27, 2003 06:12 PM
