Pulleys?
Pulleys?
Should I get the AEM Pulley's with the Altenator and Power Steering or the Unorthodox Pulley's which include Power Steering, Altenator and Crankshaft?
AEM Pulley's - $125
Unorthodox - $310
Is it that much of a difference?
AEM Pulley's - $125
Unorthodox - $310
Re: Pulleys? (X DaNish X)
The aem setup will be nicer on your motor- if you use unorthodox you will be removing the damper from the front of the crank (stock pulley) and this can be harsh on main bearings. The unorthodox would be quicker from the reduced mass.
alot of people have problems with not generating enough power for the alternater, and If the crankshaft pulley isn't balanced, it will deteriorate your engine little by little.
Even if they work fine for you, ie...no probs with them...you won't gain any power...the engine may rev a lil more freely, but you won't be that impressed.
Re: Pulleys? (DragIIcivic)
