Injector Ticking
Old Oct 12, 2003 | 07:40 PM
GPoodle
Guest
Posts: n/a
Default Injector Ticking
Well its been about a month since the SIR-II motor went in and its still ticking like a bitch. Its audible when Im driving in any RPM (even moreso since I took out cruise control a couple days ago and now have a hole in the firewall ) and just doesnt sound all that great.
I took the car to a shop and they said it was a "pissed off injector" and I checked valve clearances twice and everything is good. Ive been running 89 ocatane (a little better than the usual shitty 86 wisconsin stuff) and used a bottle of that fuel injector cleaner stuff you put in the tank.
Im just wondering if this injector ticking means one of the cylinders is leaning out or not, cause Ive driven the car hard a few times and dont notice any bad sounds or anything.
what should I do? try and find another set of OBD1 b16 injectors? or wait till I get 450's for the turbo thats comming in a few months?
Thanks guys =D
Old Oct 12, 2003 | 09:43 PM
Spartanic's Avatar
Default Re: Injector Ticking (GPoodle)
What does that shop mean "pissed off injector" anyway? I guess it means that they don't know what's wrong or how to fix it. You sure its comin from the injector? Try this, let your motor run then remove the electrical connector from the injector that's ticking, if the car suddenly bogs down and then re-idles itself then you got an injector that works, if nothing happens then that injector is a goner and needs replacin. If you want to know if your motor is running lean then take the spark plug out from the spark plug hole and inspect it. If its white then its runnin lean, brown means clean, black means too rich. Correct me if I'm wrong anybody.
If you ever notice the 89 octane gasoline is set with the same price as the 87 then don't get it unless your willing to get new injectors soon. The reason is becuase the 89 octane gasoline contains more alchol which will slowly eat away your injector seals resulting in a leaking injector. If the price sounded to good to be true then it was.
Old Oct 12, 2003 | 10:20 PM
Farmer Brown's Avatar
Default Re: Injector Ticking (Spartanic)
My Injectors tick (97 Ex) But its only really noticable with the hood up and have done it ever since I got the car. *shrugg*
Old Oct 12, 2003 | 11:02 PM
importimage's Avatar
Default Re: Injector Ticking (Djaric)
You want to hear them tick, that means that they are working. If it is abnormally loud, maybe they are needing to be tested and/or cleaned. Perhaps it is vlave tick that you are hearing also!
Old Oct 13, 2003 | 03:37 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Injector Ticking (importimage)
You should hear my Ford injectors tick.............everyone always saying my valves need adjusting.........idiots.
Yes, I'm using Ford injectors in my D16Z6. That is NOT a typo.
Old Oct 13, 2003 | 04:40 AM
BSeriesTurbo's Avatar
when I had the DSM 450 cc's in my ls motor there was a definite ticking sound from the injectors..peeps always bitched at me about adjusting my valves...little did they know
Old Oct 13, 2003 | 04:54 AM
monicle's Avatar
Default Re: Injector Ticking (Mista Bone)
what fuel rail do you use with those monsters?
Old Oct 13, 2003 | 05:48 AM
Happyman's Avatar
Default Re: (BSeriesTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSeriesTurbo &raquo;</TD></TR><TR><TD CLASS="quote">when I had the DSM 450 cc's in my ls motor there was a definite ticking sound from the injectors..peeps always bitched at me about adjusting my valves...little did they know</TD></TR></TABLE>
So that's what that is? lol. Ever since my turbo install I noticed that my motor had a little knock that was louder than usual. That's funny. Good info!
Old Oct 13, 2003 | 01:52 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Injector Ticking (monicle)
stock fuel rail and injector clips.
Used 1/2" spacer instead of the little black units on the fuel rail bolts.
boostedteg4dr
Nov 30, 2013 01:17 PM
SiRCiviC94
May 30, 2013 02:52 PM
m1nh
Jul 4, 2005 10:50 PM
TurboMiata
Aug 7, 2001 01:58 AM
