1 loud taping injector
Old May 29, 2013 | 08:23 PM
SiRCiviC94's Avatar
Default 1 loud taping injector
I haven't found much info relating to Hondas I have 680cc precision a in a turbo civic I noticed one I can really feel the pulse and hear it the rest not much if any noise or vibration... Sign of a bad one? I recently fried a ring land and it could be from it any suggestions how to check ?
Are dsm 750s too big if I grab a set I'm tuning in chrome gold tmrw and just noticed this. The car runs ok holds steady fuel pressure and af the tune is for the old b16 and pretty close
How concerned should I be?
Old May 29, 2013 | 08:49 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 1 loud taping injector
No such thing as dsm 750s. No dsm came with an injector that big
Old May 30, 2013 | 05:11 AM
SiRCiviC94's Avatar
I was looking into that... They gotta be injextor clinic
Old May 30, 2013 | 05:29 AM
tepid1's Avatar
Could be the injector, but I doubt it.
If you fried a ring land then you need to tear it down. Do it right the first time.
The noise could also be valve last or something else broken in the head.
Old May 30, 2013 | 07:15 AM
SiRCiviC94's Avatar
There's nothing broken the swap is rebuilt ground up to ensure all is good.
The injector I feel the pulse much more than the other and am getting them flow tested. Horrible timing tho
Old May 30, 2013 | 08:38 AM
Muckman's Avatar
Moderator in Chief
Swap the injector to another cylinder. See if the symptoms follow.
Old May 30, 2013 | 09:25 AM
SiRCiviC94's Avatar
I bet it would have... It's not super major like the injector was working... And wiggling the other I could feel the pulse. Given they are 680 they aren't quiet but still.
I will post the results and probably continue to clean my injectors annually. Hope all goes well I can't risk any fault up top or it will lean out and do the same thing as my last swap
I still think 350-400bhp is too much for a b16 my shop disagrees. Thinking ill hit 285whp for the time being closer to 325-350bhp
Old May 30, 2013 | 02:52 PM
SiRCiviC94's Avatar
Injectors cleaned and pushed an average of 655cc across. Seems this method has been used to test and clean injectors for ages. Good stuff...
GPoodle
Oct 13, 2003 01:52 PM
freeplay
Oct 22, 2002 04:05 PM
TurboMiata
Aug 7, 2001 01:58 AM
