Tires always end up out of round after 9-10months
Old Aug 30, 2001 | 05:47 PM
fixhondas's Avatar
Default Tires always end up out of round after 9-10months
Has anyone else experienced this? My 91 crx makes tires wear out of round. I do my own alignments (with a new Hunter rack) and it is always right on with the only spec different from stock is front camber at -1.3degrees.Front caster toe and rear camber and toe are always dead on. It doesn't matter which way I rotate them or how often I balance them. I always end up with a wicked vibration at 75mph and faster. I end up buying new tires to fix the vibration. Has new axles, all new prothane bushings, tie rod ends etc, NOTHING is loose or worn out. Hubs/rotors are true, bearings tight, whatever you can think of- What's the deal? I've gone through 6 different sets/brands/size of tires and still no difference. From 13" rims to 16" rims from 75 series to 40 series- nothing. Anyone have this problem? I've exhausted anything I can think of. I'm running eibach prokits w/ tokico illuminas, ST sways and bushings are ALL prothane.
Old Aug 30, 2001 | 06:02 PM
fixhondas's Avatar
Default Re: Tires always end up out of round after 9-10months (Teken)
yes- I have 01 civic ex rims (15x6.5) michelin XGT H4 195-50-15 past 9months. rims are true as well
Old Aug 30, 2001 | 06:07 PM
fixhondas's Avatar
we have an old jim bean spin balancer- we do lots of customer tires with no complaints.
Old Aug 31, 2001 | 01:14 PM
fixhondas's Avatar
I went to ET Paul tires today- They have a balancer that is the total ****. It's a $10k Hunter that loads the tire like it is riding on the road. One of them is phucked, 2 weren't balanced (our balancer must be a piece of ****-dinosaur- just balanced them 3 days ago). This thing even checks rim runout- the whole nine yards!It is possible that the rear tires were worn funny from the suspension being sloppy prior to prothane bushing install. I also noticed that the left axle isn't exactly true- I replaced it last October- I ordered another one from work (warranty baby) along with some hubs and bearings for my ex knuckles (big brakes). I'll start with that.
Old Aug 31, 2001 | 05:22 PM
Jared's Avatar
Default Re: Tires always end up out of round after 9-10months (fixhondas)
We have one of those at the shop. Being able to load the tire and test roadforce is the ****. Explains a lot of wheel/tire combos that were otherwise balanced but still caused speed specific vibration.
Old Aug 31, 2001 | 07:04 PM
fixhondas's Avatar
I meant that the tire is screwed- the rims are fine.
Old Sep 1, 2001 | 10:29 AM
976's Avatar
976
New User
A few days ago I noticed a hole in my tire, very small and no effect on pressure. I was still worried, I took it Les Schwab and asked if I needed it fixed. They said, "give me your keys, we will have a new tire on in 20 minutes". Gasp! It was awesome, they gave me a brand new Toyo Prox FZ4 for free. I didn't even buy the tires at Les Schwab, let alone the tire insurence. I love these guys.
Old Sep 1, 2001 | 11:46 AM
WRXRacer111's Avatar
Default Re: Tires always end up out of round after 9-10months (prsi)
How do you have a visible hole in your tire and not have any pressure loss?
Old Sep 1, 2001 | 08:27 PM
976's Avatar
976
New User
Default Re: Tires always end up out of round after 9-10months (WRXRacer111)
The hole didn't hit the tube!
Still a free $140 tire. Non-canadian...
Old Sep 2, 2001 | 10:34 PM
smokin rubber's Avatar
What kind of tires are you using. I didnt think the tubes were still around
Old Sep 3, 2001 | 11:54 AM
976's Avatar
976
New User
Default Re: Tires always end up out of round after 9-10months (smokin rubber)
Haha, you're right. I mean there is two layers, it totaly went though the first layer. Toyo FZ4 Proxy 205/40ZR17.
michael-crxsi
Jun 12, 2010 06:14 AM
yuning83
Honda Civic (2006 - 2015)
May 10, 2007 10:45 AM
k_lude
Dec 1, 2006 11:30 AM
rice_classic
Oct 3, 2005 05:37 PM
Diabolik
Mar 16, 2003 08:18 AM
