90-91 Teg seats fit in EGs??
Old Oct 12, 2003 | 01:39 PM
gribbs's Avatar
Default 90-91 Teg seats fit in EGs??
Just wondered if they bolt up prefect like the 94+ integra seats do
thanx
Old Oct 12, 2003 | 02:28 PM
gribbs's Avatar
Default Re: 90-91 Teg seats fit in EGs?? (gribbsEG8)
I did some searching, looks like i need to swap rails and possibly drill some holes
can anyone clarify??
Old Oct 12, 2003 | 02:29 PM
slammed_93_hatch's Avatar
swap the rails and it will work
Old Oct 12, 2003 | 02:49 PM
NonovUrbizniz's Avatar
Loved
Default Re: 90-91 Teg seats fit in EGs?? (slammed_93_hatch)
I don't think that's the case...
I had a set from a 93 teg and they wouldn't swap rails with my 93 ex civic seats... there is NO way to do it from what I saw..
Maybe you could swap the seat pans but I don't think so...
It wouldn't be that much of a stretch to cut off the mounting tabs off the existing rails and have new ones welded on and drill new holes that line up... they aren't far off at all...
Old Oct 12, 2003 | 03:15 PM
gribbs's Avatar
Default Re: 90-91 Teg seats fit in EGs?? (NonovUrbizniz)
Ya abuddy of mine had done this swap, he said only 3 holes line up, and if your not happy with that, nothing else short of major modification can be done
Old Oct 12, 2003 | 05:23 PM
Newman's Avatar
New User
Swapping the rails out will not work. I already looked at my DA seats and some ITR Recaro seats (along with some stock Civic rails... same as the ITR) and the lengths are off. When I put the ITR seats into my DA, using the EG/DC rails, only 2 holes lined up so I had to redrill and retap 2 new holes and it fits perfectly. Same would apply for the DA seats into an EG but they sit lower and didn't want to clear over the front hump on the floor. Unless you fab/weld up some EG rails to the DA seat, it's not really going to work that well.
Old Oct 12, 2003 | 06:40 PM
Loved
Default Re: 90-91 Teg seats fit in EGs?? (Newman)
the 90-93 teg seats I had, had ENTIRELY different rails then my civic ones... they mounted at the side of the pan and had the seatback hinge integrated into them... where as the civic rails just mounted to the bottom of the pan and the seatback hinge was seperate....
But like mentioned 3 holes DID line up and the last one could be made to fit with some welding...
If it wasn't my only car I was going to chisel off the rail mount tabs off the front of my stock civic seats and see if they would go onto the teg rails and make it fit but I think the teg rails where narrower than the civic ones... or vice versus.
Old Oct 12, 2003 | 07:08 PM
gribbs's Avatar
thanx for the replys guys...i appreciate it.....i may have to just leather mt currebt gsr seats, but i really wanted to sell them and get cheap tig seats to help find the upholstry job .....prolly wont happen till spring anyways
si_23
Apr 19, 2011 06:16 PM
civicwagonman
Jun 14, 2006 08:57 AM
homeskillet
Nov 16, 2004 07:37 PM
conceptEG
Oct 25, 2003 10:23 PM
