starting prob with ZC: need help before parts store closes!
Old Oct 12, 2003 | 10:48 AM
kyler's Avatar
Default starting prob with ZC: need help before parts store closes!
Here's the symptoms:
- crank and car will run for a couple seconds and just turn off.
- after that crank all u like and it doesnt catch at all for a couple hours.
- main relay clicks like it should when i turn the key.
- I can hear the injectors prime.
Thats all I have, any suggestions?
Old Oct 12, 2003 | 11:00 AM
tgod1020's Avatar
Default Re: starting prob with ZC: need help before parts store closes! (kyler)
same thing happened to my old car and it was the starter sometimes it would run good and once in a while the same thing you described would happen but after i changed the starter i never had the problem again
Old Oct 12, 2003 | 11:03 AM
kyler's Avatar
Default Re: starting prob with ZC: need help before parts store closes! (tgod1020)
ah, sorry I don't think I was clear.
the starter works just fine, the engine doesn't "catch"
Thanks for pointing that out to me.
Old Oct 12, 2003 | 02:58 PM
BAZ's Avatar
BAZ
Wow! Kyle, I thought you'd dropped off the face of the earth.
Whats happening?
Are you throwing any codes?
Modified by BAZ at 6:09 PM 10/12/2003
Old Oct 12, 2003 | 04:22 PM
virginia_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyler &raquo;</TD></TR><TR><TD CLASS="quote">ah, sorry I don't think I was clear.
Thanks for pointing that out to me.</TD></TR></TABLE>
DO you mean by "catch" as crank over or fire? Try the obvious see if you are getting spark?
Old Nov 4, 2003 | 09:33 PM
kyler's Avatar
Default Re: starting prob with ZC: need help before parts store closes! (BAZ)
Just to add to the archive:
The solution to the intermittent starting problem was the coil. Picked up one for a 89 teg and no problems since.
Baz: Yeah I tend to do that sometimes, but I'm back in Milwaukee now so I'll probably run across ya
twistless
Classic Hondas
Jun 19, 2011 11:23 AM
mikej94civex
Apr 28, 2010 07:49 PM
ck123
Jun 16, 2006 09:58 PM
4play4dr
Nov 29, 2005 10:47 PM
ghost_ryder35
15
Mar 19, 2004 05:04 AM
