Free Mods
Old Oct 12, 2003 | 09:21 AM
Slipknt777's Avatar
Default Free Mods
Right now im running a 93 prelude s, soon to swap h22a. i was wondering if any of you guys would know some free mods that i could do for hp increase. any help would be appreciated.
Old Oct 12, 2003 | 09:23 AM
del_parker's Avatar
Default Re: Free Mods (Slipknt777)
http://members.tripod.com/~Pre_ludE/pmods.html
Old Oct 12, 2003 | 09:44 AM
satan_srv's Avatar
Default Re: Free Mods (del_parker)
don't do the flapper valve mod. don't do the fuel pressure mods. THey both make you lose power.
Old Oct 12, 2003 | 02:34 PM
ludests's Avatar
upgraded engine grounds
Old Oct 12, 2003 | 06:25 PM
PrecisionH23a's Avatar
free?
You could remove a whole bunch of **** you don't need for increased weight reduction.
Also, you could remove your power steering and oil balancer shafts.
Old Oct 12, 2003 | 08:15 PM
bad-monkey's Avatar
remove the front sway bar
Old Oct 12, 2003 | 08:22 PM
del_parker's Avatar
Default Re: Free Mods (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">free?
Also, you could remove your power steering and oil balancer shafts.</TD></TR></TABLE>
remove the A/C as well if you're not in the South, or if you don't mind being hot.
Old Oct 12, 2003 | 09:02 PM
Matgallis's Avatar
i thought sway bars are good?
Old Oct 12, 2003 | 09:38 PM
Puki
Guest
Posts: n/a
Default Re: Free Mods (92`Legend)
Dont mean to sound like an ***, but Im stock again, with reasons.
Don't remove anything. You won't feel any "significant" difference by removing. Dont play with your throttle body, intake mani, or remove your cat.
I am waiting to start working on my lude, till I can do it right. Otherwise you won't get the results you want.
Old Oct 12, 2003 | 09:45 PM
del_parker's Avatar
Default Re: Free Mods (Puki)
LMAO, you WILL notice a difference if you remove you balancer belt and a/c...and p/s
Old Oct 12, 2003 | 10:08 PM
Puki
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">LMAO, you WILL notice a difference if you remove you balancer belt and a/c...and p/s</TD></TR></TABLE>
Im a jackass. You will notice a difference. Remove the power steering and ABS if you can while your at it.
Old Oct 12, 2003 | 11:26 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puki &raquo;</TD></TR><TR><TD CLASS="quote">
Im a jackass. You will notice a difference. Remove the power steering and ABS if you can while your at it.</TD></TR></TABLE>
What?
Old Oct 13, 2003 | 12:11 AM
Slipknt777's Avatar
I did the fuel pressure mod and the coolant bypass mod and i notice a difference in initial take off and on my high end.
Old Oct 13, 2003 | 04:51 AM
solowerks's Avatar
i think all these mods cept for weight reduction and a/c, power steering belts are ghetto and are just gona make your car ghetto with time
Old Oct 13, 2003 | 06:31 AM
killa_lude's Avatar
Default Re: Free Mods (solowerks)
what i learned is dont **** w/ your car unless you know EXACTLY what your doing...half of those mods wont do anything, more or less work...your best bet is taking stuff out for weight and taking the load off the engine...
Midori Green
21
Jul 7, 2007 08:39 AM
team 15
Jun 1, 2007 08:52 PM
BB6-213
Jan 24, 2006 08:51 PM
importdays
Sep 16, 2005 12:56 PM
Hybrid2Be
Dec 4, 2003 03:45 PM
