coilovers and camber kits????
Old Oct 12, 2003 | 08:48 AM
Boostless-Lude's Avatar
Default coilovers and camber kits????
i wanted to know what coilover give the best ride with out so much bouncing around as cheap coilovers do for a 4gen lude. My friends toll me that skunk2 are great but i wanted to hear from someone that has them. And do any of u 4gen luders have camber kits. i wanted to know is there any way i can by pass that
Old Oct 12, 2003 | 11:17 AM
aklucsarits's Avatar
New User
Default Re: coilovers and camber kits???? (Boostless-Lude)
It's not the coilover or spring that makes the ride bouncy. The ride is bouncy when the shocks do not have firm enough valving to dampen the ocillating motion of the spring. If you put 300 or 400lb/in springs over stock shocks, of course you will have a bumpy, bouncy ride. If you are going with GC or Skunk2 or whatever coilovers, you need to choose shocks that will be able to dampen the ocillations of the spring rates you choose. I know the off-the-shelf Koni Sport valving is good enough for 425lb/in springs.
Andrew
Old Oct 12, 2003 | 12:37 PM
RAB's Avatar
RAB
Default Re: coilovers and camber kits???? (aklucsarits)
Exactly what andrew said. Shocks control springs......the less dampening you have with a higher rated spring the more bouncy its gonna be. If you just want to go for "looks" lowering then I'd advise a spring rate in the range of 200-250 lbs/in.
Old Oct 26, 2003 | 09:13 AM
thank but are there any website u guys know of that i can the spring rates that i want
civicsareslow
Suspension & Brakes
20
May 17, 2006 07:35 PM
FBP_Si
Suspension & Brakes
Feb 4, 2006 03:07 AM
moores55
Jan 15, 2006 12:37 PM
LiLn81224
10
Jun 27, 2002 01:33 PM
Duck Sauce
Dec 21, 2001 07:58 AM
