IS this hydor lock ???
Old Oct 12, 2003 | 12:31 AM
S2k ALeN's Avatar
Default IS this hydor lock ???
The other day my frind washed his B18c. he sprayed some gunk remover **** all on engine (COVERD disributer, lose wires, etc) as directed. then he washed it of with hose, as directed. We dryed off all of the engine and dident start it untill about 24 hrs later. When we start car it sounds fine. then in second when u press the gas the car starts to shake and rpm dosent clim. ???? whats hapening HELP please, any ideas
Old Oct 12, 2003 | 12:47 AM
Roger's Avatar
Default Re: IS this hydor lock ??? (B18C-IVIC)
hummm, maybe one of the many sensors got moisture in it. I know that all the sensors are all waterproof, but im thinking it could be the map sensor. Wish I was there to help you target the problem. goodluck.
Old Oct 12, 2003 | 07:36 AM
rapid_roy's Avatar
No, an engine must be running and the air filter submerged to hydro lock the engine.
Something got wet, and when it dries out it will be fine (unless something shorted out).
Cheers,
Roy
Old Oct 12, 2003 | 07:46 AM
non-VTEC's Avatar
pull out all the spark plug wires and dry them out with a air blower. you probably got water down in the spark plug holes and it's causing the engine to misfire.
also check to see that the distributor cap isn't wet inside also.
HTH
Old Oct 12, 2003 | 09:36 AM
WuWarrior's Avatar
When you wash an engine, do it with the engine running or run it immediately after. This will help evaporate the water before it has a chance to get into the sensors, fusebox or anything else.
Old Oct 13, 2003 | 01:09 PM
tekstyle's Avatar
Default Re: IS this hydor lock ??? (WuWarrior)
naw.if ur engine cranks it shouldnt be hydrolock. it might be ur engine trying to burn off the extra water droplets that got in, just keep feeding it gas while ur trying to maintain the idle. do u have a open air filter? i remember it took me 1 gal of water to hydrolock my ****.
BlueIntegraBoy
May 4, 2010 12:06 PM
PaChiLa Leader
May 8, 2008 05:05 PM
after nine30
Apr 7, 2008 02:58 PM
pr0jektdc2
Nov 27, 2004 07:19 PM
pr0jektdc2
Nov 27, 2004 06:42 AM
