What Do I Do now???
Old Oct 11, 2003 | 08:42 PM
nick2kcivic's Avatar
Default What Do I Do now???
I just installed my apex'i exhaust and when I took off the factory exhaust I screwed up the cat. conv. If I get a high flow cat will it have a hole for the o2 sensor...or is it possible to make one/ Is it my best bet to buy a new oem cat or just put a high flow on ein. I can get a ractive(toucan industires) high flow resonator for like 75.00. But I do not know if it has a hole for 02. I do not want my chk eng. light on so any info is appreciated.
Old Oct 11, 2003 | 08:54 PM
clm's Avatar
clm
Default Re: What Do I Do now??? (nick2kcivic)
You could get an O2 simulator if you run an aftermaket converter or straight pipe. I'm not aware of any convertors with the 2nd O2 sensor bung, but you could also have one welded on.
Old Oct 11, 2003 | 08:58 PM
Just cut a hole in the new cat and weld it in??..I need to pass emiisions so thatis also a factor. What is a testpipe? and an os simulator?
Thanks
Old Oct 11, 2003 | 09:00 PM
clm's Avatar
clm
Default Re: (nick2kcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick2kcivic &raquo;</TD></TR><TR><TD CLASS="quote">Just cut a hole in the new cat and weld it in??..I need to pass emiisions so thatis also a factor. What is a testpipe? and an os simulator?
Thanks</TD></TR></TABLE>
Not sure about mounting an O2 sensor on a new converter.
A test pipe is a piece of pipe that replaces the converter - not legal.
An O2 simulator send the ECU a message saying there's a converter installed.
Old Oct 11, 2003 | 09:06 PM
Daniel's Avatar
Random Technology hi-flow replacement cats should have all the provisions your OEM cat has for a proper bolt-on installation. They're also 50-state legal.
Old Oct 11, 2003 | 09:09 PM
So I want to keep a cat..so this means would it be better to buy the toucan one i described or just an oem one...-sorry so many questions but dont know about this stuff..and need
one soon.
ek9mugen's Avatar
Default Re: What Do I Do now??? (Daniel)
buy one of those cheap hi flow cats for a 96-00 hatch
but be warned the cat's that look like obx mufflers sound like ****
they have a socket built it for an o2
by the way-what type of car and trim?
Modified by ek9mugen at 6:20 AM 10/12/2003
Old Oct 11, 2003 | 09:14 PM
Ivan's Avatar
senior gold member
they sell o2 bungs that you can have welded on.
Old Oct 11, 2003 | 09:17 PM
VTEC-DA's Avatar
Default Re: What Do I Do now??? (Ivan)
Of course there are highflow cats/test pipes with the second o2 bung. You every obd2 car owner just ignores the secondary o2? I've had both on my cars, got them from testpipes.com. If you are patient with the lady who answers the phones, you will get a quality product. Call, and you will see what I mean.
Old Oct 11, 2003 | 09:18 PM
2000civic 2dr ex 1.6 just installed the apexi worls sport
What are the actual benefits of high flow cat...can u give me some prices for what I should be paying....how bad is the oem one?
Old Oct 11, 2003 | 09:20 PM
Ivan's Avatar
senior gold member
I'd say waste you hard earned money on something else and have your cat fixed at a muffler shop( you messed up the flange correct?) that money can go towards something else.
Old Oct 11, 2003 | 09:21 PM
ek9mugen's Avatar
Default Re: (Ivan)
http://www.accordinglydone.com...id=70
i say go with this and call it a day.
Old Oct 11, 2003 | 09:24 PM
Default Re: (Ivan)
yes.....I messed up the flange preety bad while I was trying to get the rusted *** bolts out...how much worst case it would run me to get it fixed....the flange still has two bolts stuck in but the bolts are grinded away and there is a hole that is all messeed up near the top of the flange.....
Old Oct 11, 2003 | 09:27 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick2kcivic &raquo;</TD></TR><TR><TD CLASS="quote">yes.....I messed up the flange preety bad while I was trying to get the rusted *** bolts out...how much worst case it would run me to get it fixed....the flange still has two bolts stuck in but the bolts are grinded away and there is a hole that is all messeed up near the top of the flange.....</TD></TR></TABLE>take it to a muffler shop. somewhere cheap.not midas or some big name brand muffler shop. shouldn't be alot. waste left over money on something better then a test pipe.
Old Oct 11, 2003 | 09:28 PM
Ivan's Avatar
senior gold member
come down south and I'll fix it for 25 bucks at my shop.
Old Oct 11, 2003 | 09:31 PM
Default Re: (Ivan)
thanks for the info..i take to a shop on monday and see what they say..if they try to rape me i will check somewhere else...I guess i am just embarassed to have them see my rig job, i wanted my exhaust at least connected on there.. i have one bolt holding the cat to mid pipe right now and feel like an idiot.
Old Oct 11, 2003 | 09:39 PM
ek9mugen's Avatar
you should get your old one taken off and get the one i suggested it comes with the new flanges and a o2 bung.
Old Oct 11, 2003 | 09:43 PM
Default Re: (ek9mugen)
the price i take it is like 180 for it...do u think it is worth it? I really do nto know the difference between that one and oem
Old Oct 11, 2003 | 09:52 PM
ek9mugen's Avatar
the price depends if you are going to need new flanges to bolt it to your midpipe and header.
if you need the flanges it would be around 155
if you dont need them it will be around 90
i would highly suggest you get it with the flanges,
i think a good hi flow cat is worth the money, it will increase performance and the tone of your exhaust.
Old Oct 11, 2003 | 10:05 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9mugen &raquo;</TD></TR><TR><TD CLASS="quote">the price depends if you are going to need new flanges to bolt it to your midpipe and header.
i think a good hi flow cat is worth the money, it will increase performance and the tone of your exhaust.</TD></TR></TABLE>yeah but if he doesn't have any extensive mods, I think its worthless for 180. flanges aren't 155. most likely any muffler shop will use universal flanges. as long as it works. spend those 180 on a header or something else that would be more cost effective.
Old Oct 11, 2003 | 10:08 PM
ek9mugen's Avatar
i was saying the cat with flanges is 155 and the cat without flanges is 90
Old Oct 11, 2003 | 10:10 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9mugen &raquo;</TD></TR><TR><TD CLASS="quote">i was saying the cat with flanges is 155 and the cat without flanges is 90</TD></TR></TABLE>ahh I see If he doesn't let himself get screwed and he finds a decent muffler shop. he can get that fixed for under 50 bucks. better then 180 IMO and better then a high flow cat since his mods aren't much.
Old Oct 12, 2003 | 01:13 AM
D16Z6racing's Avatar
Default Re: (Ivan)
Random Technology cat is around $200
OEM cat is around $800
Old Oct 12, 2003 | 07:01 AM
ek9mugen's Avatar
Default Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">ahh I see If he doesn't let himself get screwed and he finds a decent muffler shop. he can get that fixed for under 50 bucks. better then 180 IMO and better then a high flow cat since his mods aren't much.</TD></TR></TABLE>
ivan is right if you can fix it at the muffler shop go for it, but if not get a good quality hi flow cat with flanges.
asianalbutt
Jun 26, 2006 09:35 PM
typesguy
Feb 25, 2004 08:14 PM
SIK IN DA HED
Dec 3, 2003 07:32 PM
EM1SiR
Nov 12, 2003 10:03 AM
Etylorcen
Jun 12, 2002 09:17 PM
