hub/spindle/axle removal problem
Old Oct 11, 2003 | 07:39 PM
VisualAutoMotoring's Avatar
Default hub/spindle/axle removal problem
on the spindle part, i've got the top ball joint off the upper arm but can get the lower ball joint to seperate..
the driver side axle i cant get it seperated off the hub...
i've hammered, lubed, pryed and everything i can think of but wont come off...
any suggestion greatly appreciated
Old Oct 11, 2003 | 07:45 PM
jdkindle's Avatar
Default Re: hub/spindle/axle removal problem (PRojectSi2)
hit it harder...........im serious (talking about the ball joint only)
Old Oct 11, 2003 | 07:48 PM
Default Re: hub/spindle/axle removal problem (jdkindle)
heheeh...the ball joint is almost flat that i've hit it sooo hard and soo many times...
and driver side axle wont seperate from hub....
what about that??
Old Oct 11, 2003 | 08:36 PM
jdkindle's Avatar
hit the arm, not the joint
for the axle.....make sure you pull the hub away while you are hitting it out....use a punch if you have to
Old Oct 12, 2003 | 11:55 AM
2camsaam's Avatar
Tom has a great write up on this with pictures
Should help you out
https://honda-tech.com/zerothread?id=382416
Old Oct 12, 2003 | 12:08 PM
Wesyder's Avatar
yes he's serious beat the **** out of it when you think your hitting it hard as you can hit it harder
Old Oct 13, 2003 | 03:50 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Wesyder)
a little $6 harbor freight tool + love taps from a 2 lb hammer does wonders.
Old Oct 13, 2003 | 06:34 AM
Default Re: (Mista Bone)
what lil Harbor Freight tool???
Old Oct 13, 2003 | 01:38 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (PRojectSi2)
http://www.harborfreight.com/c...36861
grind the point off.
Install puller over the ball joint WITH the ball joint nut loose 3 turns. Tighten the puller till it snugs up, then 1/2 to 1 turn more. Hit lower control arm with little hammer....pop.
thw_goalie
Aug 12, 2012 10:39 AM
lowtegsr
Mar 6, 2008 12:49 PM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
kshymkiw
Dec 5, 2002 06:56 AM
IntegD
Oct 20, 2001 06:35 AM
