Turbo CRX's ---Need help on turbo piping
Old Oct 11, 2003 | 07:31 PM
SpoonFed's Avatar
Default Turbo CRX's ---Need help on turbo piping
Hello just wondering if anyone knew what exactly I need to get (how many 90's 180's ect.) If u have part numbers that would be great from summit or something
Old Oct 12, 2003 | 02:34 PM
SpoonFed's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (SpoonFed)
ttt
Old Oct 12, 2003 | 02:51 PM
turbo sol's Avatar
well i am in the same boat, but i havent go tit all figured out yet, i toof off my bumper to scope it out i will try and make a diagram of what i am doing later.
Old Oct 12, 2003 | 02:52 PM
RenoRacing's Avatar
I've used all of these for exhaust and intercooler piping numerous times. I have a summit about 10 minutes from me so it's convenient.
Three should get the job done nicely. Might be able to do it w/ two and some cut angles but 3 will look smoother and make it easier on the imagination.
http://store.summitracing.com/...12597
Old Oct 13, 2003 | 03:25 PM
turbo sol's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (RenoRacing)
well i drew some quick sketches of what i have going on. the first pic is what the stock greddy pipes look like in an EG, the second one is how i am going to modify the pipes. I am going ot keep pipes 1&2 the same and get new pipes to custom fab up the rest. The intercooler is going to be flipped upside down for the CRX install to keep the pipes from hanging low and making them shorter. let me know what you guys think.
Old Oct 13, 2003 | 03:57 PM
CRX SiR T's Avatar
When Autologic (st00pid) did my pipes, they did a backdoor style intercooler. works great and looks alot cleaner
Old Oct 13, 2003 | 06:18 PM
Charlie Moua's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (turbo sol)
correct me if i'm wrong, but i was under the impression that 92-95 greddy and apexi D16 kit turbo piping and FMIC piping would work just fine in a EF with very few mods....
anyone confirm this?
Old Oct 13, 2003 | 07:24 PM
turbo sol's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (Charlie Moua)
i can say that you will have to do some cutting to make the EG piping to get it to fit. the problem is the small curved pipe that hooks around the frame to go from the turbo to the intercooler. the CRX more frame than the EG did, i felt like i would rather re route the pipes and do less structural damage to the car. just my .02
BUT if any one has done this, run greddy 92-95 turbo and intercooler piping, in a CRX please take a bunch of photos of the piping, bc it doesnt look like it will work from my perspective.
Old Oct 13, 2003 | 07:26 PM
Hoosier Daddy's Avatar
I'll take some pics of my setup tomorrow for ya
Old Oct 14, 2003 | 09:00 AM
turbo sol's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (Boost Creep)
thanks, i will be checking back to see them!!
Old Oct 15, 2003 | 06:16 PM
turbo sol's Avatar
sad, no photos.
Old Oct 15, 2003 | 06:19 PM
Jared's Avatar
On CRXs I always start with 5 U bends and end up with maybe one left depending on how many times I change my mind. That is assuming you go up from the turbo, down through where the washer tank was, to intercooler, out of intercooler, and up through the old airbox hole.
Old Oct 15, 2003 | 06:31 PM
joey1320's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (Jared)
I went to summit, bought 5 180* bend-5" diameter(bend)-2.5" tubing for 16 bucks a piece and was left with one that I din't used....
I'll have pics up tomorrow.
Old Oct 15, 2003 | 07:13 PM
TheShocker's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (joey1320)
Here's mine...
Picture a 80 degree silicon coupler in that gap. BTW it's a custom backdoor NPR intercooler
Seth
Old Oct 15, 2003 | 07:35 PM
boosted92's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (SasquatchMS)
best way to do it IMHO is rough it out with some PVC, then you have a general idea of what you need.
Old Oct 15, 2003 | 07:58 PM
crashtest Sonny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">On CRXs I always start with 5 U bends and end up with maybe one left depending on how many times I change my mind. That is assuming you go up from the turbo, down through where the washer tank was, to intercooler, out of intercooler, and up through the old airbox hole.</TD></TR></TABLE>
thats exactly what i am going to do too. but how many U bends and 90* bends got me clueless. so you bought 5...dang..sounds like a lot.. and how many couplings did you use? should i go all the same size piping from turbo to IM. or 2" from turbo - IC then IC - IM 2.5"?
Old Oct 16, 2003 | 04:22 AM
turbo sol's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (EVIL_4g_civic_si)
has anyone ran intercooler piping for the intercooler i drew in my little sketches? that is the only tricky part i am having.
Old Oct 16, 2003 | 04:35 AM
sorry I haven't taken pics yet, I'll try to get them today
Old Oct 16, 2003 | 05:48 AM
skellator_thoj's Avatar
bump..i wanna see/know how many and different kinds of bends to use..
Old Oct 16, 2003 | 07:24 AM
quis23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ran intercooler piping for the intercooler i drew in my little sketches? that is the only tricky part i am having.</TD></TR></TABLE>
my setup is like your 1st drawing
Old Oct 16, 2003 | 08:52 AM
turbo sol's Avatar
Default Re: Turbo CRX's ---Need help on turbo piping (quis23)
quis23…
do you have any more pictures of the pipes from the turbo to the intercooler? also how tall is your intercooler it looks ot be slightly larger than mine. Is it the trust intercooler upgrade for the greddy kit? I forget the #.
Old Oct 16, 2003 | 10:09 AM
quis23's Avatar
its actually a modified starion intercooler.
i'll have some more pictures of the piping up this evening.
Old Oct 16, 2003 | 10:33 AM
90civichbsi's Avatar
Default Re: (CRX SiR T)
al those that have said you did a back door setup, what size intercooler did you use? is it centered or slightly offset?
Old Oct 16, 2003 | 11:36 AM
Speed PHreak's Avatar
Default Re: (90civichbsi)
Visit the website in my signature, i've got pictures of my intercooler pipe routing.
Old Jun 29, 2004 | 11:02 PM
JOeS's Avatar
Default Re: (Speed PHreak)
Does anyone have pics of the IC piping on the driver side?
Also which kit do you all recommend? And why? Easy fit, best price, best diameter, etc.
Also, if someone have the piping laying around:
Can you take pics of them, so I know how many bents and straights are necesarry?
