will eagle rods be sufficient...?or should i switch to crowers?
Old Oct 11, 2003 | 07:04 PM
GOLDBERG's Avatar
Default will eagle rods be sufficient...?or should i switch to crowers?
12.1 compression...revving to 9.5k or so...will the eagle rod bolts stretch?anyone got EXPERIENCE with eagles in all motor cars..possibly might be using a 80 shot direct port on race gas..just unsure whether or not the rods will handle the power....unsure of exact power output but before nitrous i am just hoping for 200whp at the least..anything above that is extra..if i needa list my setup lemme know..
Old Oct 11, 2003 | 07:44 PM
turbociv's Avatar
ive heard that after 400 wheel horse the rods start to stretch. Ive used the eagle in my lsvtec, and revved to 9500 quite often but My engine developed a wrist pin nock and eventually gave. but that has nothing to do with the rod, I dont think. The Eagle rods come with arp bolts so there will be no probs there.
Old Oct 11, 2003 | 07:54 PM
RS_H22's Avatar
Default Re: will eagle rods be sufficient...?or should i switch to crowers? (GOLDBERG)
Eagle rods are a little on the heavy side... Id so go with an I beam style rod, Probe makes a decent utra lite I beam rod
Old Oct 11, 2003 | 08:52 PM
ALLMTRWHORE's Avatar
Default Re: will eagle rods be sufficient...?or should i switch to crowers? (RS_H22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS_H22 &raquo;</TD></TR><TR><TD CLASS="quote">Eagle rods are a little on the heavy side... Id so go with an I beam style rod, Probe makes a decent utra lite I beam rod</TD></TR></TABLE> I like I like!
Old Oct 11, 2003 | 08:56 PM
Supernatural's Avatar
Default Re: will eagle rods be sufficient...?or should i switch to crowers? (ALLMTRWHORE)
try not to reuse the rod bolts.......thats when they get weak
Old Oct 12, 2003 | 08:55 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: will eagle rods be sufficient...?or should i switch to crowers? (SUPERNATURAL)
Why does everyone think Eagle rods are so heavy? Because of the H-beam design? Looks can be decieving. They will be fine.
Old Oct 12, 2003 | 09:09 AM
RS_H22's Avatar
Default Re: will eagle rods be sufficient...?or should i switch to crowers? (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Why does everyone think Eagle rods are so heavy? Because of the H-beam design? Looks can be decieving. They will be fine.</TD></TR></TABLE>
We have weighed each and every rod on the market and the eagle rods are in fact HEAVY... Looks have nothing to do with weight... Our H Beams are a lot lighter than eagles H beam... Probe I beams are as of right now the lightest "shelf" rod on the market...
Old Oct 12, 2003 | 09:11 AM
Mr Hammond's Avatar
a/k/a Jomo
Cunningham has a set out stronger and lighter then Probes.
Well post the results and end all of the hearsay. I would like to see weights in grams off all aftermarekt and OEM rods.
Old Oct 12, 2003 | 09:35 AM
RS_H22's Avatar
Cunningham makes an awesome rod no doubt, pricey but worth it... The only down side to cunningham is they do not have a shelf rod... to my knowledge they are all custom and have waiting times of up to 6 weeks...
For a shelf rod with the same pricing as Eagle, Probe is the way to go
Modified by RS_H22 at 8:15 PM 10/12/2003
Old Oct 12, 2003 | 09:52 AM
Mr Hammond's Avatar
a/k/a Jomo
You are right. Cunningham's are 100% custom everytime. Why I said they can custom tailor to what ever you want. That' why I said for all motor, Eagle's are great becuase you won't overpower them, cheap, not heavier to make a difference and if you need anything more, then you might as well get cunningham's.
So post some results also.
RACEPAK
Sep 14, 2010 03:00 PM
kolumbo69
49
Dec 19, 2007 05:42 PM
94B18B1Teg
Feb 10, 2004 11:03 AM
blykins
May 29, 2003 04:57 AM
