$2200
if you have 2200, what would you do? considering you already have i/e/h?
i am thinking about ls/vtec. however, i am also considering just rebuilding the whole ls engine. if i put crower cam, aem cam gear, aftermarket piston, valve retainer and spring, with hondata tuned, how much hp would i be getting oh the wheel?
the only con i have for ls/vtec is it's not so reliable if not built right.
thanks in advance.
sorry for a long a$$ explanation.
thanks in advance.
even if built right ls/vtec will still have reliability issues. boost is your best option, the benefit of all motor is that you can slowly piece your car together. there isnt that huge initial cost of a turbo and all of the parts that keep it working. in the end you will spend a lot more money all motor for less power then a turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notsure »</TD></TR><TR><TD CLASS="quote">even if built right ls/vtec will still have reliability issues. boost is your best option</TD></TR></TABLE>
thats doesnt make sense. you really think that boost is reliable? you really think that no matter what an ls vtec isnt? where do you guys get this stuff?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">
thats doesnt make sense. you really think that boost is reliable? you really think that no matter what an ls vtec isnt? where do you guys get this stuff?</TD></TR></TABLE>
i thought the exact same thing.
"dont put a vtec head on your ls, itll break down real soon. bump boost into it and itll run just fine for ever and ever."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchGT »</TD></TR><TR><TD CLASS="quote">id run 20psi on stock b18 b4 id **** with ls/vtech...
(and YES for you tardfarms out there i am being sarcastic)</TD></TR></TABLE>
We're the tards and you are still working on clarifying engines and phones, hmm, ok.
Either way can be reliable or not. Its all in the quality of the parts, and the quality of the installation. So with that in mind, I would rather have the turbo, you can call up Greddy and have everything you need shipped to your door, where as with LSVTEC you will need to peice together your own parts. Plus, turbo will leave you with a much higher "ceiling" of power, IE, when you slap on a turbo, you can leave it at that, or build the bottom, crank the boost, and make much more power. With the LSVTEC, you do it, and your done, maybe some cams but other than that you cant get much more power out of it.
gmoore
gmoore
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">
gmoore</TD></TR></TABLE>
knew the phone was going to brought up
id have to agree with everything you say. btw, theres a nice quick spool turbo kit on sale in the sponsors marketplace.
.id have to agree with everything you say. btw, theres a nice quick spool turbo kit on sale in the sponsors marketplace.
i changed my mind about ls/vtec after reading this post.
https://honda-tech.com/zerothread?id=501372
so i boosted mine instead
wow, what is with all the threads about ls vtecs and boost?
between ls vtec and an all motor ls, definitely go with ls vtec. an all motor ls will not be very streetable (higher compression, lose a comfortable idle with longer lift/duration cams) if you really want it to be fast.
and for the record, an ls vtec does not even have to be "built" to be reliable. its merely the quality of the work and the way you drive it. specifically, you can not rev beyond the stock ls redline without upgraded rods and arp bolts. THATS where people usually screw them up. my engine consists of a stock ls bottom end, a stock gsr top end, and a gsr water pump. until i have a chance to install my eagle rods and buy a vtec oil pump, my redline is parked at 7000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -R- »</TD></TR><TR><TD CLASS="quote">i think u should start to build the motor fo boost</TD></TR></TABLE>
Yeah...rebuild your motor a bit first, then add the boost. Stock parts weren't made to handle turbo...
for that money he will probably be running low boost, which imo will perform better then most ls/vtecs and be more reliable. as far as why i think ls/vs arent reliable, is because mine is a constant headache.
it definitly was not worth the extra 25lb/ft of torque if that. granted i did not start out with an ls (bought gsr with a bad block) the point that i am trying to get across is that there are way more variables with an ls/vtec, then with a turbo. all of those variables degrade reliability and increase the expense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmintegra1994 »</TD></TR><TR><TD CLASS="quote">
Yeah...rebuild your motor a bit first, then add the boost. Stock parts weren't made to handle turbo...</TD></TR></TABLE>
They weren't made to handle boost, but they sure can with proper tuning... My bone stock B18B has been boosted for nearly a year without a single issue.
Boost that son of a bitch, I would rather boost then LS/VTEC , you can make more power easier with Turbo ls then LS/VTEC and if you dont build LS/VTEC right its gonna break down on you and i know that turbo isnt that reliable either if you dont do internal work. Boost
if i do boost, what kinda turbo kits do you suggest for daily driving?? thinking about putting 6 to 7 psi. kinda beginer, so don't need a huge turbo for now.
