hub/spindle/axle removal problem
Old Oct 11, 2003 | 03:38 PM
VisualAutoMotoring's Avatar
Default hub/spindle/axle removal problem
on the spindle part, i've got the top ball joint off the upper arm but can get the lower ball joint to seperate..
the driver side axle i cant get it seperated off the hub...
i've hammered, lubed, pryed and everything i can think of but wont come off...
any suggestion greatly appreciated
Old Oct 11, 2003 | 04:08 PM
slow_dx's Avatar
Default Re: hub/spindle/axle removal problem (PRojectSi2)
Are you trying to remove the whole assembly, or just the axle? If just the axle, I think it is just the lower ball joint that needs to be removed.
You should pick up a ball joint puller from honda or a pickle fork kit from your local auto tool retailer. If you use the pickle fork, be very careful not to tear the rubber boot on the ball joint.
I have heard that hitting the control arm with a B.F. Hammer will temporarily distort the steel so that the ball joint will pop out, but I have never had much luck with this method. Maybe because I can't bring myself to nail my car with a hammer...
Good luck!
C_Rock77
Aug 27, 2008 11:19 AM
lowtegsr
Mar 6, 2008 12:49 PM
B18CYAAA
Nov 25, 2006 01:22 PM
VisualAutoMotoring
Oct 13, 2003 01:38 PM
GruvyTune
Jul 22, 2002 10:01 AM
