clutch problems
Old Oct 11, 2003 | 03:25 PM
SIKING's Avatar
Default clutch problems
i have a delsol it was running good untill this **** with the clutch, when you take off it makes a rattle almost constant clicking noise while the clutch is out when you press it in it stops , and when the car is stopped it will make the same noise if the clutch is out but quit when you press it in
i think it may be the throwout bearing . any suggestions ? if it is the throwout how hard are they to replace ?? and should i replace the whole clutch assem.? it is the orig clutch and has 124 k on it
thanks in advance
Old Oct 11, 2003 | 03:28 PM
EG2 SiR's Avatar
Default Re: clutch problems (SIKING)
I would replace the clutch, pressure plate, pilot & T/O bearings, and have the flywheel resurfaced. The difficulty really depends on your mechanical knowledge/experience.
Old Oct 11, 2003 | 03:32 PM
SIKING's Avatar
thanks for the advice man someone told me it was valves that needed to be adjusted but i didnt think so due to the fact that it quit with the clutch engaged so thanks bro
Old Oct 11, 2003 | 03:35 PM
Run Hatch's Avatar
Default Re: (SIKING)
pilot & T/O bearings replace them.
Old Oct 11, 2003 | 03:38 PM
SIKING's Avatar
thanks i am looking into it any ideas or suggestions on a good clutch to go with
ie. exedy clutch masters act ?
any brand thats real good
thanks
Old Oct 11, 2003 | 03:41 PM
EG2 SiR's Avatar
Clutch set up depends on your engine build.... but if the engine is stock, a stock clutch is good.
Old Oct 11, 2003 | 05:18 PM
m3dia_lab's Avatar
i have the same ****!
i here its the spring for the t/o bearing
Old Oct 12, 2003 | 05:29 PM
SIKING's Avatar
i replaced the throwout bearing and had everythign replace and it works fine now so thanks guys
MiNeSEK
19
May 11, 2013 12:05 AM
uVTECiVTEC
Jul 22, 2011 12:35 PM
petty$rep
Oct 31, 2006 08:45 PM
Heinz57
16
Dec 29, 2005 07:00 PM
m3dia_lab
10
Nov 11, 2004 06:25 PM
