ek shocks fit into eg?
Old Oct 11, 2003 | 01:51 PM
vtec_2nr's Avatar
Default ek shocks fit into eg?
I'm planning to buy a set of used koni reds from an ek. Would they bolt up to an eg? i have skunk2's going on them. thanks
Old Oct 11, 2003 | 01:57 PM
Navid OG's Avatar
Default Re: ek shocks fit into eg? (vtec_2nr)
im not 100% sure but im 90% sure that they wont so...no
Old Oct 11, 2003 | 03:04 PM
milo's Avatar
Default Re: ek shocks fit into eg? (Navid OG)
yes
Old Oct 11, 2003 | 03:29 PM
EG-cellent's Avatar
Default Re: ek shocks fit into eg? (milo)
No they will not bolt straight on your eg, the bushing on the rear lower control arm on the eg is a little bigger. You can modify the bushing by shaving it down to fit the koni's off of the ek. Hope that helps.
Modified by EG-cellent at 11:17 PM 10/13/2003
Old Oct 11, 2003 | 03:37 PM
Run Hatch's Avatar
Default Re: ek shocks fit into eg? (EG-cellent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent &raquo;</TD></TR><TR><TD CLASS="quote">No they will not bolt straight on your eg, the bushing on the rear lower control arm on the eg is a little bigger. You can modify the bushing by shaving it down to fit the koni's off of the eg. Hope that helps.</TD></TR></TABLE>
Old Oct 19, 2003 | 04:00 PM
J2turbo21's Avatar
So the fronts are bolt on?Its just the rear bushing needs to be shaved which isnt a big deal,correct?Cause im thinking about buying a used set of KYB AGX for 250 shipped.
Marx
Suspension & Brakes
Oct 3, 2007 02:29 PM
truevietluv636
Oct 18, 2006 07:36 PM
Richie B
Suspension & Brakes
Jul 31, 2006 07:40 PM
vizsual00
24
May 26, 2004 10:09 PM
92JDMSiR
Apr 6, 2003 12:47 AM
