timing belt issue, can i do this?
Old Oct 11, 2003 | 01:18 PM
Mr. Softee's Avatar
Default timing belt issue, can i do this?
i forgot to line up the gear on the crank to the line on the block when i put my motor together. i am thinking i can turn the crank, line up the pulley to that line. loosen the tensioner. slip the belt off the gears, turn the gears so the arrows are facing up, slip the belt back on, tighten tensioner.
would that work?
sam
Old Oct 11, 2003 | 01:21 PM
tegasaurus's Avatar
Default Re: timing belt issue, can i do this? (94goldjungsr)
sounds like communism - great in theory or on paper, but shitty in real life.
Its not like your crank pulley is on all that tight anyway because you havn't driven it yet. In order to see the "marks" on the block/timing gear on the crank you need to take the pulley off anyway.
Old Oct 11, 2003 | 01:26 PM
Mr. Softee's Avatar
Default Re: timing belt issue, can i do this? (tegasaurus)
theres a mark on the pulley too.
Old Oct 11, 2003 | 01:47 PM
tegasaurus's Avatar
no there isn't atleast on my OBD0 factory no p/s slot pulley
btw, i took the liberty of adding "its coming..." to MY signature
Old Oct 11, 2003 | 03:03 PM
Mr. Softee's Avatar
add the beer mug t00
Old Oct 11, 2003 | 11:22 PM
Evs-One's Avatar
Solbros Owns Me
when I do a timing belt in a car that's what I do.
Throw the belt on the crank gear, throw on the lower cover, throw on pulley, line up crank pulley markings at TDC, and line up the cams and throw the belt on.
After this, I threw up a lot.....
Old Oct 11, 2003 | 11:35 PM
tegasaurus's Avatar
Default Re: timing belt issue, can i do this? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
After this, I threw up a lot..... </TD></TR></TABLE>
too many s?
excaliburcombo
Feb 13, 2016 03:26 AM
toniandfredo
Honda Civic (2001 - 2005)
Jun 10, 2007 06:28 PM
90jdmcrxdude
May 13, 2006 04:43 AM
HBK
Sep 1, 2005 09:37 AM
Jonathan_ED3
Apr 12, 2003 02:55 PM
