How to tell which valve stem seals are bad?
Old Oct 11, 2003 | 12:55 PM
Evs-One's Avatar
Solbros Owns Me
Default How to tell which valve stem seals are bad?
So I'm pulling the head off a B16 in my garage to change the head gasket. And while I'm there, I want/need to check the valve stem seals. I used to have my brother do so, but I live on the other side of the state.
The engine used to puff a little smoke at high revs when you got off the throttle- engine braking if you'd like.
Compression was perfect, so I'm leaning towards valve stem seals.
What is the best way to check these with the head off. I might just change them all for peace of mind, but if I can narrow it down easy, that would be nice.
Thanks
Old Oct 11, 2003 | 07:09 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: How to tell which valve stem seals are bad? (Emerika)
Old Oct 11, 2003 | 07:27 PM
Stripped Honda's Avatar
99-0104
they are cheap just change them all ... but you can look in the ports at the valve stems and if they have oil on them you know they are leaking
Old Oct 12, 2003 | 10:55 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: How to tell which valve stem seals are bad? (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote"> but you can look in the ports at the valve stems and if they have oil on them you know they are leaking </TD></TR></TABLE>
me....lol. Simple enough
HellaFab
Jun 28, 2011 07:37 AM
superfast666
Mar 26, 2008 12:11 PM
91-lsvtecsi
Sep 15, 2005 08:27 AM
SYN4DRDX
Jul 9, 2005 12:09 PM
sporkcrx
Jun 15, 2003 08:41 PM
