oil in spark plug chamber
Old Oct 11, 2003 | 12:50 PM
MAFA's Avatar
Default oil in spark plug chamber
1991 Honda Accord
F22A4
oil seems to have flooded one of my cylinders so that when i unplug my spark plug wire, i can see it. what should i do?
Old Oct 11, 2003 | 01:56 PM
iam7head's Avatar
Default Re: oil in spark plug chamber (MAFA)
perhap check the spark plug boot in your valve cover..are you getting al0t alot of blow by??
Old Oct 11, 2003 | 08:12 PM
Stripped Honda's Avatar
99-0104
Default Re: oil in spark plug chamber (iam7head)
it could be coming from 2 different places it could be the tube seals on your valve cover (really easy to fix) or it could be the o-rings in the lower cam caps .... a little harder to change ... but either way start off trying to change the valve cover tube seals then if it still leaks then change the o-rings... good luck
t0kyoStatus
Nov 26, 2008 07:05 PM
Jokergp
Sep 3, 2008 10:54 AM
Dj Skidz7
Apr 29, 2008 11:16 AM
Damon Reeves
May 15, 2006 10:29 AM
frozenb
Mar 31, 2005 09:12 PM
