Reccomend me a 37-degree flaring tool and tube bender
I need to flare and bend 3/16 in. stainless hard lines for direct port - any recommendations on tools and where to purchase them? I want decent quality for a good price (who doesn't?)
TIA
TIA
you should be able to use a brake line flare tool and brake line tubing bender. you can pick them up at your local autoparts store.
You can also buy pre-flared lines as well. I highly recommend this over doing it yourself since it is much less of a headache. I bought a flaring tool from Autozone but it didn't work- wouldn't hold the tubing. I then realized that Advance Auto sold pre-flared tubing and have been using it since (added ITR ABS and had to route new lines).
On an unrelated side note- no one should have any excuses for not doing the 1" MC upgrade since the proper tubing (inverted aka double flared) is readily available.
Ben
Ben
how huch is the preflared tubing - I already have the tubing though - but some of those tools were expensive so I guess either way.
Modified by slashDEVslashNULL at 6:18 PM 10/12/2003
Corksil
46
Jan 21, 2012 07:44 PM
Jake92eg
19
Apr 9, 2008 11:30 AM
