smoke comes out of exhaust
Old Oct 11, 2003 | 11:18 AM
vxnine's Avatar
Default smoke comes out of exhaust
hey i have 92 civic sedan and everytime i rev the engine smoke comes out.. and when its in idle there is smoke too just not noticible
Old Oct 11, 2003 | 11:22 AM
handa's Avatar
Default Re: smoke comes out of exhaust (frankcivic)
check your oil & oil filter, it's the most obvious reason for the smoke.
Old Oct 11, 2003 | 11:24 AM
=GAME='s Avatar
blue smoke? or black smoke?
Old Oct 11, 2003 | 11:26 AM
vxnine's Avatar
i just changed my oil the other day though..
blue smoke
Old Oct 11, 2003 | 11:33 AM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic &raquo;</TD></TR><TR><TD CLASS="quote">i just changed my oil the other day though..
blue smoke</TD></TR></TABLE>
= burning oil. Maybe you have too much.
Old Oct 11, 2003 | 11:41 AM
vxnine's Avatar
Default Re: smoke comes out of exhaust (EG2 SiR)
hmm i think thats the problem too now. becuase i put 3 3/4 qt oil when im supposed to put 3 only?
will the oil burn off by itself?
Old Oct 11, 2003 | 11:55 AM
tominos's Avatar
blue smoke is burning oil. get the oil to the right amount. then see if it still does it i guess. then if it does, do a compression test. oil could be leaking past rings.
Old Oct 11, 2003 | 12:07 PM
vxnine's Avatar
Default Re: smoke comes out of exhaust (tominos)
how do i get the oil to the right amount? do i just hold the accelerator and burn the oil?
Old Oct 11, 2003 | 12:56 PM
goodbyegti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic &raquo;</TD></TR><TR><TD CLASS="quote">how do i get the oil to the right amount? do i just hold the accelerator and burn the oil?</TD></TR></TABLE>
that is now the most retarded thing i have read on here! use the dipstick you dumbass, if it's too high drain some out, don't burn it off, if you run your engine with excess oil you can cause serious damage.
Old Oct 11, 2003 | 01:00 PM
TorganFM's Avatar
Default Re: smoke comes out of exhaust (goodbyegti)
i think that was a joke... but if im wrong hahaha
Old Oct 11, 2003 | 01:01 PM
goodbyegti's Avatar
yeah i sure hope so
Old Oct 11, 2003 | 02:54 PM
Lord Helmet's Avatar
Default Re: (goodbyegti)
haha that has to be one of the funniest **** I heard in a long time
Old Oct 11, 2003 | 04:40 PM
vxnine's Avatar
Default Re: (sleeperciv)
im glad that i entertain you guys
okay i drained some of the oil and theres not as much smoke anymore..
on the lower revs there is no smoke
but on the higher revs there is smoke. do i just keep draining oil until it goes away or just leave it like it is?
any response is appreciated
Old Oct 11, 2003 | 04:41 PM
EG2 SiR's Avatar
Default Re: (frankcivic)
check the dipstick, dipstick... J/k man. The level should fall just short of the second hole.
Old Oct 11, 2003 | 05:24 PM
vxnine's Avatar
Default Re: (EG2 SiR)
okay i checked its about an 1/8" short of the second hole. it smokes when i rev the engine a bit high. my car doesnt have a tachometer but i know im not reving to where it would be redlining.
Old Oct 11, 2003 | 05:28 PM
EG2 SiR's Avatar
Does the motor have a ridiculous amount of miles?
Old Oct 11, 2003 | 05:52 PM
vxnine's Avatar
yes sir 168,327mi. &lt;--so thats the problem?
Old Oct 11, 2003 | 05:54 PM
EG2 SiR's Avatar
possibly.... might have oil getting into the combustion chamber from the valve seals...
Old Oct 11, 2003 | 07:24 PM
tominos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic &raquo;</TD></TR><TR><TD CLASS="quote">im glad that i entertain you guys
any response is appreciated</TD></TR></TABLE>
so umm, u sure you know how to check the oil?
there should be a mark where it says full on the dipstick. don't go past this mark. it could hurt the seals in your engine.
so if there's no smoke except when u redline it, could just be running really rich. just a suggestion. wait, that's black smoke, ha.
Duhul
May 20, 2010 11:18 AM
Torlie
May 26, 2006 06:17 AM
peel17
Feb 1, 2005 11:28 AM
T25So
Sep 8, 2004 11:39 AM
citanest
Oct 18, 2001 09:27 PM
