You guys adjust with cam gears on forced induction
Should i put adjustable cam gears on my engine b18c1 with the turbo, do you guys adjust it, i had it on my sohc turbo and had it at zero which was worthless?
Put adjustable gears on it and tune it. I have gained 17 ft-lbs and like 9 whp from cam gear tuning on one set up then another some minimal gains like 3whp and 5ft-lbs. It is all about the combination! Good luck.
girliehonda
Apr 23, 2005 11:49 AM
