How to convert compression psi to ratio?
Old Oct 10, 2003 | 10:00 PM
brent_G's Avatar
Default How to convert compression psi to ratio?
Well i have always wondered how to get the compression ratio. Lets say a b18b1 with 190 across the board...whats the ratio on that? 10-1? anyone can give me an idea of how that works that would be cool.
Old Oct 10, 2003 | 10:12 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: How to convert compression psi to ratio? (screamincivik)
can't be done.
Old Oct 11, 2003 | 12:22 AM
civickiller's Avatar
Default Re: How to convert compression psi to ratio? (Mista Bone)
you kind a can but not too accurately because the more the psi goes up the higher the comp ratio so yeah but idk if anyone knows the exact ratio to psi
Old Oct 11, 2003 | 05:10 AM
keebler65's Avatar
Default Re: How to convert compression psi to ratio? (civickiller)
i think it can be done, however, it requires more numbers than you want to deal with. you're better off finding out what the rating is when they come from the factory, then find out the percentage, like this:
(your psi)/(factory psi) * 100 = percentage of original
Old Oct 11, 2003 | 06:42 AM
blah13's Avatar
Default Re: How to convert compression psi to ratio? (keebler65)
It is nearly impossible to determine. First you would need to do a leakdown test and find that percentage, as that will lower the psi of the compression test. Then you have to determine the ammount of carbon buildup in each cylinder as excessive buildup will increase the psi. Then you need to know the psi for an engine with no leakdown and no buildup....so yeah, pretty hard.
Old Oct 11, 2003 | 09:30 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: How to convert compression psi to ratio? (blah13)
then how do you factor in the cam timing?????
If you retard the intake cam, you get a low cranking psi.
I stand by my original statement.
Old Oct 11, 2003 | 09:54 AM
MrTodd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">then how do you factor in the cam timing?????
I stand by my original statement.</TD></TR></TABLE>
Agreed.
You could get over 200 PSI with a 9:1 CR, if the ring seal was excellent and if the vavles were sealing just as effectively.
Compression testing isn't going to tell you anything regarding the actual compression ratio.
Old Oct 11, 2003 | 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">It is nearly impossible to determine. First you would need to do a leakdown test and find that percentage, as that will lower the psi of the compression test. Then you have to determine the ammount of carbon buildup in each cylinder as excessive buildup will increase the psi. Then you need to know the psi for an engine with no leakdown and no buildup....so yeah, pretty hard.</TD></TR></TABLE>
u dont have to determine anythign because thats the compression ratio, carbon buildup, ok as the carbon builds up your compression ratio increase, i mean if your trying to find stock compression ratio then that would be hard, but if yoru tryin to find out the compression ratio you have now, u dont have to do that because right there you would be finding out hte compression ratio you have right then.
Old Oct 11, 2003 | 02:58 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">
u dont have to determine anythign because thats the compression ratio, carbon buildup, ok as the carbon builds up your compression ratio increase, i mean if your trying to find stock compression ratio then that would be hard, but if yoru tryin to find out the compression ratio you have now, u dont have to do that because right there you would be finding out hte compression ratio you have right then.</TD></TR></TABLE>
Yep.
Old Oct 12, 2003 | 12:15 AM
brent_G's Avatar
Default Re: How to convert compression psi to ratio? (fourthgenhatchB17)
yeah i was trying to thnik of a way to figure it out myself...but couldnt thats why i came to you guys maybe someone knew of a way to figure it out...seems to be there isnt much of a way.
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
ace8
Dec 1, 2009 04:16 PM
EG6 Love
Feb 15, 2008 05:06 PM
HatchBox
Aug 4, 2003 03:41 PM
d15nonvtec
Feb 4, 2003 07:31 PM
