Best thing to do when i leave car.
Old Oct 10, 2003 | 09:16 PM
xkhalil333x's Avatar
Default Best thing to do when i leave car.
is there any plug or fuse i can pull out of my car if i plan on leaving it some where for 2 days? pleaselet me know its a 98 tegra
Old Oct 10, 2003 | 09:17 PM
GSRrR's Avatar
Default Re: Best thing to do when i leave car. (xkhalil333x)
just take the ecu. but no matter what, they can still tow...
Old Oct 10, 2003 | 09:18 PM
ATF Kuk's Avatar
Default Re: Best thing to do when i leave car. (GSRrR)
they can also bring another ECU with them.
Old Oct 10, 2003 | 09:24 PM
anything a lil simpler than removing the ecu?
Old Oct 10, 2003 | 09:38 PM
RiceRacist's Avatar
Default Re: (xkhalil333x)
doesnt get to much simpler than removing the ecu
if you cant do that than just dont drop it off
Old Oct 10, 2003 | 09:39 PM
no ic an remove the comp but i was jsut wondering if there was a lil quicker method
Old Oct 11, 2003 | 01:45 AM
vteg's Avatar
New User
Kill switch for the feul pump. Rottweiler in the back seat. Gun tower
There was a thread recently if you are interested in kill switches.
Old Oct 11, 2003 | 10:07 PM
lilbennyxx's Avatar
ECU is the fastest way i can think of also...
-Unhook the battery? But that does no good, only works for a little while. Unless they are dumb and not check under the hood.
Old Oct 11, 2003 | 10:16 PM
Default Re: (lilbennyxx)
what if i just wanna pull out a fuse or something when i park my car in my driveway over night? let me know
Old Oct 11, 2003 | 10:27 PM
lilbennyxx's Avatar
I'm not really sure which fuse to pull out...but i'm thinking under the hood to the top left for my car..i haven't tried...but it had labels for each fuse so take out the one you think that will make your car not start up.
-Just get a killswitch
Old Oct 14, 2003 | 04:37 AM
rjr162's Avatar
Default Re: Best thing to do when i leave car. (1993sir)
http://www.stickdeath.com They have all your Automotive Security needs lol
Old Oct 14, 2003 | 08:15 AM
Default Re: Best thing to do when i leave car. (rjr162)
98 tegra
Old Oct 14, 2003 | 04:18 PM
PetroGuyX's Avatar
who brings an ecu with them?
Old Oct 15, 2003 | 03:39 PM
mattduskater's Avatar
try just unpluging the wiring harnis from the fuse box. Or just try unpluging one at a time and tryin to start it.
Old Oct 16, 2003 | 08:26 AM
4uhataz's Avatar
Pull out your fuse for the ecm, fuel pump, ignition, head and tail lights.
Old Oct 16, 2003 | 08:40 AM
patdemps's Avatar
Default Re: (4uhataz)
just take out the ECU if you don't want it stolen. do it the right way man. don't cut your teg short
also, if they want to tow, its there's anyway. so either way your stuck. i'd keep it somewhere inclosed instead of out in the open
Old Oct 16, 2003 | 06:31 PM
Xazzu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.stickdeath.com They have all your Automotive Security needs lol</TD></TR></TABLE>
LOL, subtle dude, very subtle.
it's just two days dude, why such fuss?
Old Oct 16, 2003 | 06:41 PM
Xsi's Avatar
Xsi
You could take the main fuse from under the hood, it would kill all the power. I think they are 80 amps and they aren't as common as the flat blade fuses so they might not have one with them.
Old Oct 17, 2003 | 01:31 PM
m3dia_lab's Avatar
take out the brakes and main fuses under the hood
Old Oct 17, 2003 | 05:57 PM
blackhatchy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkhalil333x &raquo;</TD></TR><TR><TD CLASS="quote">is there any plug or fuse i can pull out of my car if i plan on leaving it some where for 2 days? pleaselet me know its a 98 tegra</TD></TR></TABLE>
take the key
Old Oct 17, 2003 | 06:19 PM
rjr162's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">who brings an ecu with them? </TD></TR></TABLE>
I would if i was going to take a 97+ Prelude... get by the Immobilizer system real damn fast.
Old Oct 19, 2003 | 05:56 PM
x00gsr's Avatar
unplug ecu fuse and starter wire.
strict 9 ef
64
Feb 14, 2004 12:45 PM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
cp_harrington
Jan 20, 2003 08:35 PM
ts9790147
May 31, 2002 08:49 AM
illusion
Feb 18, 2002 03:02 PM
