itr rear sway w/ neuspeed rear tie bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01GsR »</TD></TR><TR><TD CLASS="quote">what are the pros and cons of the itr rear sway bar. i also have a neuspeed rear tie bar. will they work together or will the tie bar not fit? tia. </TD></TR></TABLE> no cons in the itr swaybar..unless you think getting rid of understeer is a "con".
pros---more neutral balance...rear end comes around more...
do it with the bsq kit..
cons....it costs money....but not that much....good bang for the buck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01GsR »</TD></TR><TR><TD CLASS="quote">ok so my neuspeed tie bar will fit by the looks of thaiphob's pic my last question is would a rear strut bar and trunk brace compliment the itr sway bar?</TD></TR></TABLE>
did you click the link i posted? you need to modify the tie bar to fit. but after all that it complemented the sway bar fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by comptechgsr »</TD></TR><TR><TD CLASS="quote">pros---more neutral balance...rear end comes around more...
cons....it costs money....but not that much....good bang for the buck</TD></TR></TABLE>
Some people say that it rubs against the ABS line (ITR sway). It's nothing to worry about though is it? Which mounting kit does that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01GsR »</TD></TR><TR><TD CLASS="quote">i was reading throught the archives and i read concerns of the itr sway bar ripping out the subframe. would my neuspeed tie bar prevent this in any way? </TD></TR></TABLE>
no the tie bar wont prevent the sway to be ripped out of the subrame. i think the only way the sway bar could rip out of the frame if you dont use the bsq/ beaks kit.
