Help! How to remove the Thermostat housing nuts on G3 Integra.
Everything has gone alone fine until I got to the thermostat housing, I got the top nut off but cannot get the bottom of. Here is the picture of what I am talking about:
http://www.team-integra.net/se...D=229
I did what they mention and remove the top part of the air box, but that only along enough space for the top nut but the bottom nut is ....... a PAIN IN THE ***.
I cannot remove the bottom nut. Only way I can get to it is use a long extension for the ratchet but then the 10mm socket won't fit entirely over it. I don't want to try and remove it like thus, which is going to strip the nut.
Any tips or help on how to remove that lower nut??? I was rolling along until I got stuck there......
I think I had to use a regular wrench, but I can't remember for sure. Take off the whole intake including the intake pipe.
I just took a look, but I'm not sure if that will work. Part of the dam starter and some other wire is in the way....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed »</TD></TR><TR><TD CLASS="quote">deepsocket, swivel, then extensions are your friend. very easy.</TD></TR></TABLE>
LOL
thats what you think!
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I think I had to use a regular wrench, but I can't remember for sure. Take off the whole intake including the intake pipe.</TD></TR></TABLE>
Ditto.
Gearatchets are your friend; otherwise it'll take you forever.
Ditto.
I'm going to try a deep socket tomorrow and see what happens. If not, i'm just going to put everything back together and take it to the dam shop, local shop said they will charge $35...........I'm kinda pissed because it's just that ONE NUT and off it goes and ready for me to put the new one in
*After looking over the top nut, I think I'm going to need a new one. Kind of rounded off the tip........
, off to the Acura STEALERSHIP and see how much they charge for one of these. Last time I was there to pick up a VALVE COVER GROMMET, they freaking ROBBED ME at $6 a POP!!!*
.*After looking over the top nut, I think I'm going to need a new one. Kind of rounded off the tip........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big reds »</TD></TR><TR><TD CLASS="quote">
LOL
lol, thats what I know, I removed it before
LOL
