H-series tranny question : which tranny better for boost?
im boosting a h23-vtec......... its a street/strip car... not going to be daily driven, but i want somethin good for the 1/4 mile but i dont want it to be topping out at 120 etc..... which is better? h22 or h23? im in the process of seaching now... so let me know
with 24.5" tall tires and the h22 trans i cannot go through the traps in fourth. with the h23 trans i can. my et's did not change at all changing transmissions but i did gain some mph. getting a h series trans into fifth gear sucks.
Hopefully someone can lay some info on me. I heard that the only difference between the 22 and 23 is 5th gear true? I was also wondering if anyone knows if the diff uses needle or ball bearings? thanks-pdang
same final drive, same first gear, the h22 has closer ratio gears. i will look tomorrow and let you know about the bearings.
IMHO, a good setup for a high HP turbo car would be the f22 trans w/ h22/23 final drive and spooled/locked.
thats just me though.
i run an all motor F22 in my 91 Accord w/ a 93 h22 trans. 22" slicks im shifting into 5th 150ft. before the finish line. also, im only spinning to 6800rpm.
ok i will be using about 24-24.5 inch slicks too so im prolly gonna want the h23. they make LSD's for the h23 correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Option2 eg6 »</TD></TR><TR><TD CLASS="quote">ok i will be using about 24-24.5 inch slicks too so im prolly gonna want the h23. they make LSD's for the h23 correct? </TD></TR></TABLE>
yes, Quaife, same part as the h22 differential
yea im shopping for one now... anyone? haha who was it on here that i saw sellin quaifes for like 7somethin shipped? ill be in the market for that too soon.
How's the LSD in the JDM H22 tranny? Is it fairly strong? I haven't heard much about them. M2B4 I think is the code...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Option2 eg6 »</TD></TR><TR><TD CLASS="quote">yea im shopping for one now... anyone? haha who was it on here that i saw sellin quaifes for like 7somethin shipped? ill be in the market for that too soon. </TD></TR></TABLE>
you're thinking of KTeller8 : https://honda-tech.com/zero...01111
And to the other guy, good luck finding a jdm h22a LSD that isnt attached to a motor
