Will 17" Wheels affect my DYNO RESULTS?
Old Oct 10, 2003 | 01:39 PM
TypeRuz's Avatar
Default Will 17" Wheels affect my DYNO RESULTS?
Just wondering b/c I'm dynoing my baby tomorrow, and I'm currently running 17" wheels with 215/40 17's. It's about 0.3" taller than stock, and each wheel with tire weighs about 42 lbs.
Is it affected, if so....by about HOW MUCH ?????
Thanks!
-on a side note, anyone know the weight of stock wheels with tires?? (or at least the weight of the wheels themselves?)
Modified by typeruz at 2:10 AM 10/11/2003
Old Oct 10, 2003 | 10:10 PM
TypeRuz's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (typeruz)
anyone?
Old Oct 10, 2003 | 10:48 PM
morepoop4u's Avatar
you may lose like only 1-3hp. stock is like 36lbs ish
Old Oct 11, 2003 | 08:08 AM
TypeRuz's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (George Knighton)
THANKS!!!
Old Oct 11, 2003 | 08:16 AM
Tommy_Gunns's Avatar
That's about 10 lbs heavier than my old stock wheel/tire combo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz &raquo;</TD></TR><TR><TD CLASS="quote">each wheel with tire weighs about 42 lbs.
Old Oct 11, 2003 | 09:53 AM
HYREV2NR's Avatar
It's been a while ago when I read this article in SCC where they took a Civic SI & put it on the dyno. They added 1 thing after another...turbo, exhaust, pulleys, you name it. The dyno #'s started to climb & then fell when they added the 17" whs & tires. To my suprise they fell a little more when they added an AEM big brake system. A 6 or 7 HP loss. Just remember any extra rotating mass takes that much more HP away from your dyno run.
Old Oct 11, 2003 | 10:28 AM
georgiajdm's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (HYREV2NR)
yes you will. i read the same scc article and the drop was around 3-6hp through the entire rev band.
bigger wheels will give lower hp numbers but will handle better.
Old Oct 11, 2003 | 03:04 PM
RacerZook's Avatar
Just remember to have the same wheels on the car the next time you dyno it/tune it so you get an accurate before and after reading.
Old Oct 11, 2003 | 04:06 PM
B2FiNiTY's Avatar
Depends on the dyno. If it's a dynapack, wheels are removed.
Old Oct 11, 2003 | 04:08 PM
Type-Rare#1248's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">
bigger wheels will give lower hp numbers but will handle better. </TD></TR></TABLE>
?? i dont think so
Old Oct 11, 2003 | 08:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
I'm thinking you're talking about his comment about the handling.
If you're going from 6" wheels and 195 010's to 7" wheels and 225 Hoosiers, it is really irrelevant if the diameter is 15" or 17".
In most circumstances, when most people change to a larger diameter wheel, they are also getting wider wheels, putting more rubber on the ground, and putting <u>better</u> rubber on the ground.
Theoretically, you're right.
You could cause handling to decay by changing wheels like that, but in most cases the handling is improved. </TD></TR></TABLE>
ya, given equal width of rims and tires, i am pretty sure the 17s aren't better than 15s...thanks for clarifying though
i am pretty sure he didn't consider the width part though...if he did, he would've been more clear
Old Oct 13, 2003 | 01:26 AM
all stock's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (Type-Rare#1248)
stickier tires also affect dyno results.
Old Oct 13, 2003 | 07:16 AM
Calavera's Avatar
Default Re: Will 17" Wheels affect my DYNO RESULTS? (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">stickier tires also affect dyno results.</TD></TR></TABLE>
lol, you mean if I dyno with slicks I get higher results?
and about the tire/handling: doesn't sidewall have any effect on handling too? just curious.
EDIT: sidewall, always get that mixed up with firewall.
Modified by Calavera at 7:17 PM 10/13/2003
Old Oct 13, 2003 | 12:38 PM
Reid's Avatar
Global Moderator
Default Re: Will 17" Wheels affect my DYNO RESULTS? (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">and about the tire/handling: doesn't firewall have any effect on handling too? just curious.</TD></TR></TABLE>
Firewall?
Old Oct 13, 2003 | 01:18 PM
DutchITR1689's Avatar
Theoretically, it shouldn't influence the power output of the engine. If it's measured with an acceleration dyno, it will affect measurement very very little because the drum is much heavier.
But if you use a brake dyno (constant rpm), you won't see the difference.
Old Oct 13, 2003 | 01:19 PM
Default Re: Will 17" Wheels affect my DYNO RESULTS? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Firewall?</TD></TR></TABLE>
Hahahaha, I think he meant sidewall.....
Old Oct 13, 2003 | 02:37 PM
all stock's Avatar
stickier tires reduce dyno hp. more friction.
spoonlongblock
20
Feb 6, 2006 04:20 AM
bo0st lee
Aug 3, 2005 01:53 PM
NightHawkC5
Jan 12, 2003 06:54 PM
Mike B
Aug 22, 2002 05:59 PM
ej20_chris
Dec 23, 2001 12:02 PM
