throw out bearing????
Old Oct 10, 2003 | 01:04 PM
92civeg's Avatar
Default throw out bearing????
before i start i just want to say that i have searched and found nothing to be very informative!
my problem is whenever i push the clutch in and out it squeaks everytime... and is very annoying...also whenever i let off slowly i hear a loud sssscccrrreeeeeeeechhh ...i lubed up every moving part i could get to
(inside and under the hood of my car) with a moly based grease and it continues to squeak
please help i can only turn up my radio so loud
thanks!
Old Oct 10, 2003 | 01:19 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
i feel you on this one.....it use to happen to me in my hatchie too....then i sold it....never found out what it was....come on someone...any ideas...
Old Oct 10, 2003 | 02:12 PM
Snake-Shadow's Avatar
Similar to the problem I am having on my domestic, except it only happens when I have the clutch engaged. It is definitly the TOB on my car. On my Lude I have experienced no such problems. Sounds like you are on track with the TOB.
? How many miles and what is your driving style?
Old Oct 10, 2003 | 05:39 PM
92civeg's Avatar
Default Re: (Snake-Shadow)
ive only put 5,000 miles ont the new clutch (its an act stage 2) but i do have the tendency to keep the clutch in at long lights
Old Oct 10, 2003 | 06:58 PM
Mohudsolo's Avatar
Default Re: (92civeg)
Is the sound under the hood or inside the car? If under the hood, sounds like the TO bearing. If more inside, is your car a cable clutch? I've seen on several cars that when the cable is old and the strands are starting to break, it creaks quite a bit. Will make the sound both going down and up.
Old Oct 10, 2003 | 07:04 PM
92civeg's Avatar
Default Re: (Mohudsolo)
its a hydrolic tranny......its hard to pinpoint the sound.....but id say under the hood
Old Oct 11, 2003 | 12:56 PM
92civeg's Avatar
Default Re: (dgonzals)
bump
Old Oct 11, 2003 | 02:37 PM
tub_sephiroth's Avatar
I had this same problem. Lucky, the dealer replace my TO bearing under warranty. Good luck.
IBriaIN
Aug 12, 2008 08:09 AM
prjctwhteg
Oct 30, 2007 05:02 AM
jaywo_23
Sep 26, 2007 02:06 PM
GeorgeY
Apr 18, 2003 03:10 PM
TypeR 508
Apr 11, 2002 12:52 PM
