Throttle Position Sensor - Removal
Old Aug 30, 2001 | 06:28 AM
unFOB4U's Avatar
Default Throttle Position Sensor - Removal ???
I just recently got a JG throttle body. While removing my stock T/B, I noticed that there are no slots for a screwdriver, nor for a socket, to remove the Throttle position sensor, instead the screw is just covered up in white paint (like it was cut of itentially). I looked it up in the book and it doesn't say anything about removal. Any tips on getting it out? Or do I have to purchase a new one?
[Modified by unFOB4U, 3:33 PM 8/30/2001]
Old Aug 30, 2001 | 06:48 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Throttle Position Sensor - Removal ??? (unFOB4U)
you have to cut a slot in it with a dremel tool and a cutoff wheel. You cannot buy the TPS seperate from the T-body from the dealer.
Old Aug 30, 2001 | 07:11 AM
unFOB4U's Avatar
Default Re: Throttle Position Sensor - Removal ??? (B18C-EJ1)
I've been wanting to buy a drummel tool for awhile, but I just been putting it off.
Old Aug 30, 2001 | 10:58 AM
brian b's Avatar
New User
i've been doing some research on the TPS sensor lately (mine is slightly broken but only sometimes...) here's a couple part #'s from summit, they're holley sensors at about 32 bucks each.. i'm having a hard time even finding a picture though.. any chance theres anybody with access to these parts that could measure them? the TPS sensor is just a variable resistor.. it takes +5v and ground and makes some number between based on how far its turned
HLY-543-29 Throttle Position Sensor
HLY-543-3 Throttle Position Sensor
cryingsuns
Mar 20, 2011 01:13 PM
TASAuto.com
Performance
Jul 19, 2009 05:35 PM
jdmferioeg8
Sep 17, 2008 05:13 PM
cazper8890
Mar 2, 2007 08:25 PM
Orangedragone
18
Sep 14, 2006 02:52 PM
