what fuel pressure?
Old Oct 10, 2003 | 11:01 AM
jeremy.'s Avatar
Default what fuel pressure?
i am installing a fpr this weekend...my setup is stock b16head/gsr block with jdm itr pistons...itr im, walbro 255 fuel pump, exhaust, and intake. what should i set my fuel pressure to? is 50 psi alright?
Old Oct 10, 2003 | 04:11 PM
mastarolla's Avatar
Default Re: what fuel pressure? (ek_jeremy)
do you have something like a Greddy A/F monitor to see how stoich the mixture is? Unless you do or have something else to tune off of...i wouldnt mess with the FP.
Tune it to about 14:1 i think for all motor and a little richer (13:1) for turbo...
Old Oct 11, 2003 | 12:26 AM
TimoneX's Avatar
New User
That's probably a bit high. Try 44psi or so. Just keep cleaning and rechecking your plugs if you're not going to check it with a wideband O2. You'd rather it was a bit rich than too lean, but get it about right before you start redlining it.
Old Oct 11, 2003 | 10:13 AM
asubennett's Avatar
Default Re: what fuel pressure? (TimoneX)
factory injectors and rc injectors are designed to yeild optimal spray pattern at 42 psi. But if you are running stock injectors I would bump it up to 45 psi to compensate for your mods.
Old Oct 11, 2003 | 10:35 AM
lsvtec101's Avatar
i run a b&m fpr with the walboro 255lph pump , the lowest the b&m will go is like 42 and my autometter a/f gauge reads in the stoch at wot even those i know the autometer gauges aernt dead on i know its in the ball park.
Old Oct 11, 2003 | 11:04 AM
smokey2.0's Avatar
Default Re: what fuel pressure? (aemcivic_02917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 &raquo;</TD></TR><TR><TD CLASS="quote">i run a b&m fpr with the walboro 255lph pump , the lowest the b&m will go is like 42 and my autometter a/f gauge reads in the stoch at wot even those i know the autometer gauges aernt dead on i know its in the ball park.</TD></TR></TABLE>
that's what my b&m does, i can't get it to go lower than 42 psi! i'll stick with that since i'm running rc's 370cc injectors, i can't wait to dyno so i can see where my A/F is at now
Old Oct 11, 2003 | 11:08 AM
-KangaRod-'s Avatar
Default Re: what fuel pressure? (mastarolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastarolla &raquo;</TD></TR><TR><TD CLASS="quote">
Tune it to about 14:1 i think for all motor and a little richer (13:1) for turbo...</TD></TR></TABLE>
Isn't that a little lean? I'm not sure, but my spidey sense is tingling.
Old Oct 11, 2003 | 03:28 PM
asubennett's Avatar
Default Re: what fuel pressure? (-KangaRod-)
14.1 one is not ideal for every day driving but for a track car it is
centraldriver29
Jun 5, 2014 04:55 AM
aalb1
Nov 2, 2005 10:47 AM
turbosi03
May 27, 2003 06:34 PM
Mr. Softee
Mar 6, 2002 05:28 PM
DIRep972
Nov 28, 2001 08:40 PM
