RSX Head Swap on Si bottom end (info to be had?)
Old Oct 10, 2003 | 09:30 AM
Buetang's Avatar
Default RSX Head Swap on Si bottom end (info to be had?)
I tried searching for info on this... I know people have done it, I figured it would be a nice 'upgrade' while saving for the DC5-R K20A.
Does anyone have any links to info on this, or experiences to share about this?
How much is involved? Swap the heads, switch ecu's...etc. ?
Would this swap cause any problems to the weaker Si bottom end?
thx for any info.
Modified by Buetang at 1:45 PM 10/10/2003
Old Oct 10, 2003 | 09:46 AM
1abSi's Avatar
Default Re: RSX Head Swap on Si bottom end (Buetang)
first of all good luck finding the head...second...i think one mag did it and as did
aj-racing did it..but i do not see the specs on the site...you can email which i did, but didn't get a whole lot of info...how about find one for me and i will let you know what happens...and as far as the bottom end...a prb head was put onto a k24 block and it is reving just fine...and it is not like that block was setup for those rev's stock
Old Oct 10, 2003 | 09:50 AM
Buetang's Avatar
Finding the head isn't a problem
Knowing if it would be worth it however...is.
Old Oct 10, 2003 | 10:04 AM
1abSi's Avatar
Default Re: (Buetang)
let me "borrow" it and i will slap it on and tell you
Old Oct 10, 2003 | 10:07 AM
fireant's Avatar
Check with Hondata, because I think they can simply reflash your Si's ECU with the RSX-S software + Hondata tune, instead of getting the whole new ECU/Keycode thing.
Old Oct 10, 2003 | 10:11 AM
1abSi's Avatar
Default Re: (hatch2k)
yeah that can be done if you were thinking of getting hondata...but would run you quite a bit more, if you didn't want the extra rev's that the hondata gives....
Old Oct 10, 2003 | 02:00 PM
that guy steveee's Avatar
Default Re: (1abSi)
it can be done, my friend lee has done it on his already with a tranny swap. he saved ALOT of money since one of his buddys who bought a type-r motor sold him the head for like 500! Its not hard at all. The bottom end can take it too. the type s block just has a few more oil squirts to help with the higher revs, but a good aftermarket oil cooler would take care of the heat as well.
all in all i am doing it as soon as i can find a legit head from a K20A2 and ECU for cheap.
Old Oct 10, 2003 | 02:32 PM
HaTcH_BmX's Avatar
Default Re: (simann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simann &raquo;</TD></TR><TR><TD CLASS="quote">it can be done, my friend lee has done it on his already with a tranny swap. he saved ALOT of money since one of his buddys who bought a type-r motor sold him the head for like 500! Its not hard at all. The bottom end can take it too. the type s block just has a few more oil squirts to help with the higher revs, but a good aftermarket oil cooler would take care of the heat as well.
all in all i am doing it as soon as i can find a legit head from a K20A2 and ECU for cheap.</TD></TR></TABLE>
i think everybody is in the same situation !!.. everybody wants to swap the head.. i been looking for one since august.. and didnt have any luck..
where did you find yours??
Old Oct 10, 2003 | 10:04 PM
acuratech's Avatar
Default Re: (HaTcH_BmX_Ep3 kid)
I got a friend that drives a mustang that has a type s head. I cant get him to come off of it though. Dont know what he thinks he is going to do with it..
allmightykseries
Apr 9, 2009 07:41 PM
NOFX
Oct 29, 2007 02:16 PM
dc5RickK20
Jun 11, 2006 06:00 AM
WSU K20
Sep 8, 2004 04:07 PM
mustninty
Aug 22, 2004 07:09 AM
