too much fuel ??? HELP
Old Oct 10, 2003 | 09:04 AM
joeski's Avatar
Default too much fuel ??? HELP
ok lemme give a lil backround first i had an accicent in july and the car has had the front end up on jackstands since then. the car has been started and ran at least once a week. well i finally got the front end all back together i started the car and it ran went inside came back out like 10 min later went to rev the motor and it stalled. now when i go to start the motor it backfires and dumps alot of fuel i jus redid spark plugs and put a fuel cleaner in it..oh yea presure is at 52psi do u guys think it could be
1)bad fuel from sitting so long.
2)because the motor was on an angle it needs to sit flat for a while
3) something worse
im stuck right now and could use some advice
oh yea its a 95 gsr motor and is not throwing any code
walbrow 255lph
b&m FPR
Old Oct 10, 2003 | 09:35 AM
1_bad_EF's Avatar
Default Re: too much fuel ??? HELP (joeski)
too high of fuel pressure for one
how much gas in the tank? You should take the car off jackstands and let it even out.
^^^probably the problem^^^^^
mmuller's Avatar
Mad Scientist
i dont think is your gas, check your dizzy(ignitor).how do your plugs look?
Old Oct 10, 2003 | 09:50 AM
joeski's Avatar
Default Re: too much fuel ??? HELP (mmuller)
got brand new plugs prob less than a quater tank left well let me refrase i jus put new plugs in but the old ones were BLACK
Black R
Oct 9, 2011 01:36 PM
dreadhead89
Dec 26, 2008 09:14 PM
Achenar
Mar 11, 2007 11:46 AM
Dan-Dillinger
Apr 21, 2006 11:26 AM
vtec94civic
Apr 16, 2005 09:40 AM
