Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
cheap diy emergency "kill"/ off switch for local events..... how?
Old Oct 9, 2003 | 09:49 PM
Black R's Avatar
25 Year Member
Default cheap diy emergency "kill"/ off switch for local events..... how?
Apparently they require a "kill" switch external of the vehicle at a local track if you have relocated the battery. Requirement is that it disconnects the battery and alternator, effectively killing the car.
How can I make one for cheap on my own? Home depot shopping list anyone?
Old Oct 9, 2003 | 09:59 PM
Tyson's Avatar
Default Re: cheap diy emergency "kill"/ off switch for local events..... how? (Black R)
do an archive search on "kill switch" in this forum. lots of good info. basically gotta buy a 4pt switch and wire both the positive battery cable and alternator power wire to the switch. use stereo power cable is fine, or jumper cable on the cheap.
Old Jun 18, 2004 | 09:17 PM
Black R's Avatar
25 Year Member
Default Re: cheap diy emergency "kill"/ off switch for local events..... how? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">do an archive search on "kill switch" in this forum. lots of good info. basically gotta buy a 4pt switch and wire both the positive battery cable and alternator power wire to the switch. use stereo power cable is fine, or jumper cable on the cheap.</TD></TR></TABLE>
.....does it have to be a 4pt? Isn't there a way I could use a 2 point kill switch?
I was looking at the 100amp fuse under the hood and the wires that go to that... if I interrupt those, it should kill everything, right?
Bringing this one back from the dead, but procrastination has me just now trying to get this thing installed.....
{EDIT} I found some pertinent threads:[/EDIT]
https://honda-tech.com/zerothread?id=636955
https://honda-tech.com/zerothread?id=645060
Modified by Black R at 2:10 AM 6/19/2004
Old Jun 19, 2004 | 04:23 AM
Knestis's Avatar
You do need to disconnect both if you have an alternator. The problem is that the car will run on the juice produced by the alternator if the engine is turning so just cutting the battery won't do it. I did a bunch of shopping and the best deal I found was at Summit, if I recall correctly.
K
Old Jun 19, 2004 | 08:44 AM
celica73's Avatar
New User
Default Re: cheap diy emergency "kill"/ off switch for local events..... how? (Knestis)
Is the idea of the kill switch *just* to shut the car off? Is it also there to kill possible ignition sources under the hood?
I run a Crane ignition and I *know* for a fact I can kill either of the two hot wires to the ignition box and the car will stop immeditately, not doubt in my mind. Why do I need to kill battery and alternator if I can kill the spark that easily?
Scott
Old Jun 19, 2004 | 01:17 PM
Knestis's Avatar
Default Re: cheap diy emergency "kill"/ off switch for local events..... how? (celica73)
Most rules stipulate that a kill switch disconnect the battery from the entire electrical system and shut off the car. Check yours to find out specifically what is required.
K
Old Jun 19, 2004 | 01:31 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">Most rules stipulate that a kill switch disconnect the battery from the entire electrical system and shut off the car. Check yours to find out specifically what is required.
K</TD></TR></TABLE>
The rules most likely require what he said....should say something like this in rule book (all power must be removed from vehicle to reduce risk of further damage when an accident occurs)
Type-Spaz
Aug 19, 2011 07:19 AM
julianbc2
Jan 25, 2009 12:11 PM
philosofy1
11
Dec 8, 2007 09:33 PM
SHG_EasyE
Jun 28, 2007 07:25 PM
underpressure02
Apr 23, 2007 08:42 AM
