Hondata?
how user friendly is the hondata for a first time tunner, cause out here in australia we dont have many people how have had any experiance working with the hondata
It is pretty user friendly as far as changing values on the air/fuel and timing maps, fuel cut, and VTEC. The catch is, you need some way to measure the affects of any changes you make. A dyno to measure power, and a wideband to see what the air/fuel ratio is doing.
thankz for the info, its just every time ive tried to get some sort of info on the hondata i ended up where i started, and with the wideband is that like a hand controller of some sort?
A wideband is a wideband oxygen sensor. The wideband measures the oxygen content of the exhaust and the tuning software converts the signal from the wideband to an air/fuel ratio value.
