weird tranny grind
Old Oct 9, 2003 | 06:40 PM
743power's Avatar
Default weird tranny grind
I have a weird tranny grind in my LS tranny. It has stock clutch/flywheel/diff and full of honda mtf. When I shift into second, no higher than 4000 rpms, it will occasionaly grind. It does it more shifting mid turn. It's only grinded above 4000rpms once or twice in the 10k I've been using it and that was probably my fault.
Anybody have any insight? It's just annoying and I've never heard of this before. . .
Old Oct 9, 2003 | 06:53 PM
junya16's Avatar
Default Re: weird tranny grind (743)
sounds like the 2nd gear synchro is startin to go...try some gm synchromesh tranny fluid, it helps w/ little problems such as yours
Old Oct 9, 2003 | 07:56 PM
743power's Avatar
Default Re: weird tranny grind (junya16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the 2nd gear synchro is startin to go...try some gm synchromesh tranny fluid, it helps w/ little problems such as yours</TD></TR></TABLE>
Think it could be the synchro? I'm taking this motor out sometime this winter, so I'll wait til my next oil change and put some fresh honda MTF in, that gm stuff is mucho dinero.
Old Oct 9, 2003 | 11:41 PM
92 civic VX B18c's Avatar
HT Black Ops
Try using GM syncromesh Friction modified, I know its a few more $'s then honda MFT but it's well worth it, it made my 3rd gear grind go away, not to mention makes my shifter feel like butter
Make sure you get the friction modified stuff not the reagular stuff Square bottle not the round one...
here's a link about it
https://honda-tech.com/zero...age=1
90gs
Nov 1, 2006 12:37 PM
97turboteg
Sep 7, 2006 03:45 PM
trooper0641
18
May 6, 2005 06:50 PM
RagingAngel
Nov 8, 2002 07:13 PM
ill phil
15
Sep 4, 2002 10:37 PM
