YS1 Xsi tranny eats Oil?
Old Oct 9, 2003 | 05:33 PM
bossman032's Avatar
Default YS1 Xsi tranny eats Oil?
when I did my swap I put oil from the top part of the tranny.
today when I try to drain the Oil to PUT some GM friction stuff
bam no oil came out of the Drain Hole...
wtf?
do Trannys eat OIL or what.. where did all my tranny Oil GO?
also my 3rd gear was grinding looks like the GM **** is working little...
Old Oct 9, 2003 | 08:10 PM
Malgerus's Avatar
Default Re: YS1 Xsi tranny eats Oil? (bossman032)
I hear synchromesh gets better once it's cycled a few times... meaning when it's heated up and cooled down multiple times. If your synchros are completely shot, then synchromesh won't help much. It's more of a crutch than a fix.
As for the tranny eating oil, I don't think that they do under normal conditions. Are you sure that you're not leaking it out??
Old Oct 9, 2003 | 08:14 PM
bossman032's Avatar
Default Re: YS1 Xsi tranny eats Oil? (Mr. S)
I think its leaking from somewhere but I haven't took a Look I am not even sure if its leaking
hopefully the synchromesh gets better as the days pass make my slight 3rd grind go away at high rpms...
Old Oct 9, 2003 | 08:15 PM
T-Mo's Avatar
My Prelude was leaking because of a bad seal where the axle goes into the tranny. I changed it immediately. No problems since then. I don't know if our cars have that seal.
Old Oct 9, 2003 | 09:24 PM
Fobtions's Avatar
Default Re: (T-Mo)
maybe your tranny is ground down like mine at the bottom. it leaks a few droplets when sitting sometimes, who knows how much leaks when its rolling.
junk95civ
Feb 26, 2010 03:05 PM
HondaHeddie
Sep 29, 2006 07:40 PM
drastikmeasurez
Jul 22, 2005 04:59 PM
cyrock
Oct 4, 2004 12:55 PM
