Gettin the Inovative MSBC to work right?
just what the topic says were having some problems holding boost. Company said to use co2 to hold boost has anyone else got a idea how to use this really excited to use it but now were having to many problems. any advice any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gzrmoto »</TD></TR><TR><TD CLASS="quote">just what the topic says were having some problems holding boost. Company said to use co2 to hold boost has anyone else got a idea how to use this really excited to use it but now were having to many problems. any advice any help </TD></TR></TABLE>
I think you only need to use co2 if you are using dual wastegate.
Vic
Vic
Co2 will help you keep the controller seeing your target boost level. Adjust it to the max amount of boost you want to see and that should help. It still seems to vary the boost 2-3 lbs 30,28.2,30.4,27.6 etc...... but it is better than without it.
So it this co2 is used then will you still beable to have the progressive build up of boost? and will it always go to lets say max boost is 30 and you only want 15psi will it go to 15 or 30?
thanks for the help
thanks for the help
