my d16y7 motor shakes
someone plz help me. i have a 98 ek, (d16y7 stock motor) and everytime i come to a stop, my motor starts to shake. any suggestions on how to fix it??? plz help!
Modified by ekguy at 11:29 PM 10/9/2003
I had the same problem with my 96 hatch when I first bought it. It has the stock D16Y7 and it idled very rough and would almost die when I would push in the clutch and come to a complete stop at a light. It turned out that before I owned the car the people had the timing belt changed and it was off 1 or 2 teeth on the cam pulley and they had fully retarded the ignition timing to make up for it. So I would check your timing first and see where it is at with a timing gun and then adjust the timing and see if it gets better or worse, then you can come to a conclusion on if it is the timing or not. Well hope this helps, Jordan.
CIVIC96DXcp
Apr 19, 2005 07:47 PM
1987CRXSi
Dec 29, 2004 07:12 AM
