290 Prelude Injectors on B16 (or LsVtec)
Old Oct 9, 2003 | 01:22 PM
-KangaRod-'s Avatar
Default 290 Prelude Injectors on B16 (or LsVtec)
What do you guys think about Prelude 290 injectors on a stock B16 with a standard PR3 ecu? What about on an LsVtec? Will it run too rich?
Old Oct 9, 2003 | 02:55 PM
-KangaRod-'s Avatar
Bah, I'll dyno it and see what happens.
Old Oct 9, 2003 | 03:09 PM
-KangaRod-'s Avatar
https://honda-tech.com/zerothread?id=610082
I think I'll get them
Old Oct 9, 2003 | 03:49 PM
junya16's Avatar
Default Re: (-KangaRod-)
gotta love the search button...good luck w/ your build
Old Oct 9, 2003 | 04:14 PM
JD Milan's Avatar
Default Re: (junya16)
tune it out to run a more lean mixture, I think they are fine, might be dumping a little more fuel, like I said before tune them down some if you are dumping some.
Old Oct 9, 2003 | 04:26 PM
junya16's Avatar
Default Re: (JD Milan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD Milan &raquo;</TD></TR><TR><TD CLASS="quote">tune it out to run a more lean mixture, I think they are fine, might be dumping a little more fuel, like I said before tune them down some if you are dumping some.</TD></TR></TABLE>
what a statement...haha..absolutely amazing
Old Oct 9, 2003 | 08:51 PM
goforbroke's Avatar
MEAT PATTY
But why? And prelude injectors flow at 345. And why in the world would you want to swap out your stock b16 injectors if your not making a gang load of power? Search is your friend.
Old Oct 10, 2003 | 10:54 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (goforbroke)
92-96 Preludes are Peak & Hold 345cc
97+ are saturated 290's.
Just out of curiostiy though if you have a stock B16A and stock ECU with no tuning device, what would possess you to want to put prelude injectors in there?
Old Oct 10, 2003 | 11:04 AM
-KangaRod-'s Avatar
I'm more thinking for my LsVtec, but I figured since I was going to the dyno I'd want to have something to change, but I dunno, they might take 45 mins to change anyway.
Did you say the peak and hold ones are 345s?
Cause i think I have the P & H ones.
I have the ones that'll work on the stock injection system on a 90 crx (which I believe is peak and hold.)
Old Oct 10, 2003 | 11:15 AM
Mr Hammond's Avatar
a/k/a Jomo
Yeah you def. have the 345's. The later of the two are for OBDII cars. I would deffenetly not put those in your B16A or LS/VTEC unless you are 11.5:1 plus and Stage 2 cam and up and having full tuning capabilites.
Old Oct 10, 2003 | 12:45 PM
-KangaRod-'s Avatar
they are definitely too big to be run on the stock PR3 ecu...
what about when I convert to Hondata, they should be good then?
Goddamm Obd-1, I get all pissy just thinking about it.
Old Oct 10, 2003 | 01:07 PM
Mr Hammond's Avatar
a/k/a Jomo
You can do wonders with Hondata. Will be no problem.
Old Oct 10, 2003 | 02:51 PM
1RMDave's Avatar
i was always told they are 290's
Old Oct 10, 2003 | 03:14 PM
-KangaRod-'s Avatar
Default Re: (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">i was always told they are 290's</TD></TR></TABLE>
I was always told stock 5.0's are fast...
that doesn't make it true.
Old Oct 10, 2003 | 11:53 PM
satan_srv's Avatar
92-96 Prelude VTEC Peak and Hold (Resistor Box) Injectors are 330cc, after cleaning and flow testing at RC they get up to 340-345cc
97-01 Prelude Saturated (no box) injectors are 290cc, and they probably flow a little better after cleaning and testing at RC as well.
Old Oct 11, 2003 | 09:35 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (satan_srv)
RC got 345cc out of the OBD1's and 290 out of the OBD2's.
Old Oct 11, 2003 | 09:48 AM
BERT-O's Avatar
Default Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">RC got 345cc out of the OBD1's and 290 out of the OBD2's.</TD></TR></TABLE>
very true, I have a email to prove it from RC, lol
Old May 3, 2004 | 06:16 PM
-KangaRod-'s Avatar
Default Re: (BERT-O)
What kind of modification do I need to do to put these in my ITR manifold? The injectors are physically too big and I didn't want to start drilling. Should I modify the manifold or the grommety things.
Also, will my car just simply run wayyyy to rich on these (with stock FP and ECU), like seeping past the rings rich?
doublejz
13
Aug 13, 2005 11:57 PM
jdmb1697ek
15
Apr 11, 2005 08:03 AM
lopey
Apr 1, 2002 03:07 PM
Turbohatch
Sep 27, 2001 06:12 PM
