aem no bypass aem w/bypass ingen cia?
first i would jsut like to tell you that here on Honda-Tech we havethis wonderful thing called "Search Function", you can use by simply clicking on the word "Search" in the upper right corner of your screen.
AEM bypass valve =
this is what happens to your valves when you drive through a construction area with debris in the air using an AEM bypass valve
AEM bypass valve =
since your from MN, i suggest putting it on. it rain and snows alot over there. better be safe than sorry.
and yes, you cut the tube in half where ever you want to mount it. read the directions or go to ntpog.org for more info.
