CV Boot Set -install
Old Oct 9, 2003 | 11:22 AM
optimusA4's Avatar
Default CV Boot Set -install
I am helping a friend with a 1996 Civic LX. Are there any concerns with a CV Boot Kit install? I mean do I need to replace any seals or washers (in addition to what comes with the kit) when I take the drive shaft off to put the new stuff on? Also will there be enough lube with the kit or do I need more? And if so what kind?
I've done a few of these on other cars, mostly German and a few military vehicles.
I already did a search of the tech archives and didn't find what I needed.
Any help would be great. Thanks.
Old Oct 9, 2003 | 03:22 PM
92sleepR's Avatar
New User
Default Re: CV Boot Set -install (optimusA4)
Easy as pie
You need to remove the inner joint. Remove the three bearing carrier by removing the snap ring at the end of the half shaft. Then just slide the old boots off and slide the new ones on. The boot replacement kit should come with all the lube you need. DOnt overfill the new boots or they will leak (explode is more like it. I did that once and it wasnt pretty. I was cleaning axle grease off the engine bay for hours )
Mike
Old Oct 10, 2003 | 07:24 AM
optimusA4's Avatar
Default Re: CV Boot Set -install (92sleepR)
Coolio, thanks Mike.
Hopefully I can find OEM parts for cheap.
itr1235
May 4, 2008 06:22 PM
jdmcrx_echelon
Jan 4, 2007 06:56 AM
Ben_si
12
May 24, 2005 08:44 AM
thegoods217
Jan 17, 2005 08:35 PM
winlo408
Aug 24, 2004 12:03 PM
