GSR rods in LS block
Old Oct 9, 2003 | 06:52 AM
advanracing62's Avatar
Default GSR rods in LS block
I'm going to start a new project, and just for fun I wanted to tinker with configuring the motor differently. I really don't want to use the GSR crank in the LS block, but can I use the rods? I'm thinking that they are a bit shorter, which would help to slow the pistons down a tad. Not too sure on this though. Anyone have any input?
Old Oct 9, 2003 | 08:50 AM
IN VTEC's Avatar
Default Re: GSR rods in LS block (advanracing62)
GS-R rods are longer. Higher R/S ratio means slower piston speeds.
The pistons will stick out a little. How much depends on the compression height of the pistons.
Old Oct 10, 2003 | 07:08 AM
TimoneX's Avatar
New User
Default Re: GSR rods in LS block (IN VTEC)
Not to mention GSR rods have smaller big ends.
LOL
It's an oxymoron...like jumbo shrimp! Kewl!
Yes I am switching to decaf.
Old Oct 11, 2003 | 01:09 AM
Rocket's Avatar
Default Re: GSR rods in LS block (TimoneX)
GSR rods can't be used on a LS crank.
Old Oct 11, 2003 | 07:18 AM
chrisCNL's Avatar
Default Re: GSR rods in LS block (Rocket)
You got to get new custom pistons and custom con rod made. if you want to use the GSR rod, you got to bore it to ths size of the LS journal.
Old Oct 11, 2003 | 11:10 AM
Default Re: GSR rods in LS block (chrisCNL)
so then, obviously, I'd have to run the GSR crank with rods to get that to work... hmmm... still pondering the effects
Old Oct 11, 2003 | 11:23 AM
chrisCNL's Avatar
there is always ways of getting things to work.
Old Oct 11, 2003 | 11:51 AM
notsure's Avatar
that would be a gsr stroke, with gsr rods in a LS block. not really sure what you are looking to do, but that is probaly not it, you would reduce your displacement slightly from 1834cc to 1797cc.
Old Oct 11, 2003 | 01:19 PM
Default Re: GSR rods in LS block (notsure)
there is a reason for the de-stroke. I want to be able to maintain revolutions in the 8-9k range for sustended periods of time. I'm thinking that the GSR crank/rods would be a bit safer than the LS for this very function. I'm only looking to get about 250-275whp from the motor, which should be easy to do...
Old Oct 11, 2003 | 09:57 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">You got to get new custom pistons and custom con rod made. if you want to use the GSR rod, you got to bore it to ths size of the LS journal.</TD></TR></TABLE>
Journal size is the same. Big end with is different.
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
grand champ
Feb 20, 2008 10:10 AM
methodz55
11
Mar 12, 2005 08:46 AM
slimcivic95
Aug 31, 2004 07:01 PM
Quicky
Nov 25, 2002 05:12 PM
